  sudden slug
sudden slug by dishpro
Started on: 05-17-2014 07:41 PM
Replies: 14 (302 views)
Last post by: dishpro on 06-28-2014 12:58 PM
dishpro
Report this Post05-17-2014 07:41 PM Click Here to See the Profile for dishproSend a Private Message to dishproEdit/Delete MessageReply w/QuoteDirect Link to This Post
any ideas why my 84 suddenly is running really rough ,tested compression good tried different coil , module ,map sensor,tps ,throttle body, idles okay but when rev it up and let drop back to idle gags and pukes then slowly smoothes out again , also new plugs ,wires, o2 sensor , timing gears? kinda thinkin maybe intake manifold leak any ideas would be great p.s. only about 90,000 miles total
steve308
Total ratings: 58
Report this Post05-17-2014 08:16 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Plugged exhaust (Cat converter)
Csjag
Report this Post05-17-2014 08:30 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Or a fuel pump going or a clogged fuel filter
dishpro
Report this Post05-17-2014 08:36 PM Click Here to See the Profile for dishproSend a Private Message to dishproEdit/Delete MessageReply w/QuoteDirect Link to This Post
took cat out ,fuel pump and filter only 4000 miles on
steve308
Total ratings: 58
Report this Post05-17-2014 08:52 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Second guess -- to many new parts But --- recheck timing and look for those leaks.
84fiero123
Total ratings: 325
Report this Post05-17-2014 09:00 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Take the distributer cap off and look at the pickup coil, if the insulation around it is gone it will need to be replaced. it should have a wrap of white tape like material all around the outside if any of that is missing, that would be my guess.
Steve
dishpro
Report this Post05-17-2014 09:17 PM Click Here to See the Profile for dishproSend a Private Message to dishproEdit/Delete MessageReply w/QuoteDirect Link to This Post
I drove to indy for the 30th anni. it was fine it started getting less power on the way home I just ordered a new pickup coil I see mine has a few cracks in the magnet also planning on replacing intake manifold gasket because I have a spare that I will polish up anyways
dishpro
Report this Post06-23-2014 02:35 AM Click Here to See the Profile for dishproSend a Private Message to dishproEdit/Delete MessageReply w/QuoteDirect Link to This Post
replaced intake gasket and tbi gasket compression test vacuum check still nothing found I am lost at why it's running so rich any help would be greatly appreciated
dishpro
Report this Post06-23-2014 02:37 AM Click Here to See the Profile for dishproSend a Private Message to dishproEdit/Delete MessageReply w/QuoteDirect Link to This Post
dishpro
Member since Nov 2009
also rebuilt distributor and checked timing
Report this Post06-23-2014 09:07 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
A bad CTS will make the engine run rich, and may not trigger a code.
dishpro
Report this Post06-23-2014 04:08 PM Click Here to See the Profile for dishproSend a Private Message to dishproEdit/Delete MessageReply w/QuoteDirect Link to This Post
put new cts in also .anyone know of a good way to check o2 sensor circuit? acts like not operating
Report this Post06-23-2014 08:24 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
If the O2 sensor was not working you would get a code. There may be codes saved in your ECM without the light going on.
dishpro
Report this Post06-24-2014 01:10 PM Click Here to See the Profile for dishproSend a Private Message to dishproEdit/Delete MessageReply w/QuoteDirect Link to This Post
there is no codes stored and i can unplug o2 sensor while running no change
KurtAKX
Total ratings: 128
Report this Post06-25-2014 01:39 PM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sigh. If I had a dollar for every time this was inappropriately suggested...
dishpro
Report this Post06-28-2014 12:58 PM Click Here to See the Profile for dishproSend a Private Message to dishproEdit/Delete MessageReply w/QuoteDirect Link to This Post
as posted earlier the cat has been removed already
