  8 4 4spd. trans removal
8 4 4spd. trans removal by larry mimbs
Started on: 05-17-2014 01:31 PM
Replies: 6 (263 views)
Last post by: larry mimbs on 05-18-2014 01:45 PM
larry mimbs
Report this Post05-17-2014 01:31 PM Click Here to See the Profile for larry mimbsSend a Private Message to larry mimbsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is it easier to remove 4 spd. trans from 84 from top or bottom?
Total ratings: 290
Report this Post05-17-2014 04:26 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes
Report this Post05-17-2014 04:48 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got a Lift?
Jason88Notchie
Report this Post05-17-2014 05:31 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice Gall. That would be so awesome to a guy like me to have access to. There is so much more I could do to a car with the correct tools. But hey, not complaining. I adapt with what I got and improvise. Kind of makes us think out side the box. And I do love challenges.
Jason88Notchie
Report this Post05-17-2014 05:36 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jason88Notchie
Member since Oct 2009
To answer the OP question, you drop from the bottom. You can support the engine from the top, unbolt mounts, unbolt cradle, drop cradle with transmission. That is about as simplistic as I can make it. Be sure to search other threads in the archives and be safe. Be prepared for the worse. I had a nightmare with the rear cradle bolts. Again. I had to improvise to get those out, and adapt for reinstall.
Report this Post05-17-2014 07:13 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can make it simpler.
Loosen, but leave the front cradle bolts in and tilt the cradle down with engine and tranny still attached to the cradle. Support engine from the top and tranny comes out the driver's side wheel well. Might have to remove some components from engine to clear trunk sheet metal when tilting the cradle, but it's doable.
larry mimbs
Report this Post05-18-2014 01:45 PM Click Here to See the Profile for larry mimbsSend a Private Message to larry mimbsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, Patrick.
