  Pinging?
Pinging? by samt
Started on: 05-15-2014 12:47 PM
Replies: 3 (220 views)
Last post by: Gall757 on 05-15-2014 04:15 PM
samt
Report this Post05-15-2014 12:47 PM Click Here to See the Profile for samtSend a Private Message to samtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is it possible for engine pinging to come and go or am I barking up the wrong tree? only makes the noise around 3000 rpm but will come and go..I tried premium gas made no difference...
Report this Post05-15-2014 02:30 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Which engine?
Under acceleration only?
samt
Report this Post05-15-2014 02:39 PM Click Here to See the Profile for samtSend a Private Message to samtEdit/Delete MessageReply w/QuoteDirect Link to This Post
2.8 and under acceleration only...hard to tell but it seems to be from the passenger side more than drivers...will go away and no signs of it even going up hills...then come back..very random..car runs fine although a little rich
Report this Post05-15-2014 04:15 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
I think your comment about running rich is the key. If you get a lot of carbon deposits in the cylinders....valves...etc. you will get detonation under some circumstances. If there is no SES light, it's not bad, but over time it gets bad. Could be the CTS is a little off, so the computer is making things too rich. Could be that your timing is a little off so things are not burning up completely. A cheap attempt at a fix might be some injector cleaner in the fuel.
