  Connecting an aftermarket stereo to the car
Connecting an aftermarket stereo to the car by notaguru
Started on: 05-15-2014 12:26 PM
Replies: 7 (778 views)
Last post by: GodSend on 05-17-2014 05:44 PM
notaguru
Report this Post05-15-2014 12:26 PM Click Here to See the Profile for notaguruClick Here to visit notaguru's HomePageSend a Private Message to notaguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm restoring this '88GT after many years in the sun. Almost everything works properly now, and I'm down to the details...
There is an odd subwoofer under the dash and what seems to be a controller in the overhead panel. Presumably there's a separate amplifier somewhere, and power/signal feeds. Unfortunately, the previous owner installed a (good quality) Sony stereo/CD, but apparently did not connect the subwoofer. I therefore need a wiring diagram that includes physical locations of the various wires, paths, and connectors. Can you provide it, or refer me?
Of course, my FIRST choice would be an original Fiero front end, with EQ. But even then I'd need wiring help because surely the PO has cut/spliced.
Thanks!
Report this Post05-15-2014 12:51 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
You can SEARCH for Performance Sound for a lot more information. Be sure to select the archives.
https://www.fiero.nl/forum/Forum2/HTML/128961.html
Bump
Report this Post05-15-2014 12:58 PM Click Here to See the Profile for BumpSend a Private Message to BumpEdit/Delete MessageReply w/QuoteDirect Link to This Post
That 6.5" sub and overhead controller are stock. (presumably, Many came with them)
You have many options for replacements. Obviously stock and about any aftermarket, but also look into replacing it with a factory pontiac deck with CD player. Will give you the convenience of a CD player, but will still appear stock. You can also add an MP3 hook up to a stock player. There are many threads on here about both of these options and which decks will and wont work.
[This message has been edited by Bump (edited 05-15-2014).]
fierosound
Total ratings: 286
Report this Post05-15-2014 02:09 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
What the subwoofer system consists of:
http://calgaryfieros.com/OSGdocs/subwoofer.html
Calgary time/temp
PaulJK
Total ratings: 237
Report this Post05-16-2014 06:28 AM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
The stock subwoofer enclosure will have to be modified to use a 6.5 " speaker because the stock one was not 6.5" .
huracan2015
Report this Post05-17-2014 12:47 PM Click Here to See the Profile for huracan2015Send a Private Message to huracan2015Edit/Delete MessageReply w/QuoteDirect Link to This Post
Since when is there a subwoofer in a stock Fiero? Was that an option? I don't have one...
fierosound
Total ratings: 286
Report this Post05-17-2014 05:05 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Optional 86-88
RPO codes
UQ6- speaker , sub woofer (86-88)
UL5- radio delete (all)
U63- AM (84-87)
UL6- AM w/clock (84)
UU9- ETR AM/FM stereo (84)
UL1- ETR AM/FM stereo w/clock (84-85)
UM7- ETR AM/FM stereo w/clock and seek&scan (86-87)
UU7- ETR AM/FM stereo w/clock and cass. player (84)
UU6- ETR AM/FM stereo w/clock,cass., and EQ (84)
UM6- ETR AM/FM stereo w/clock,auto reverse cass.,and seek&scan (85-88)
UX1- ETR AM stereo/FM stereo w/clock,auto rev. cass., and seek&scan and EQ (85-88)
UT4- ETR AM stereo/FM stereo w/clock,auto rev. cass., and seek&scan,EQ and touch controls (85-87)
[This message has been edited by fierosound (edited 05-17-2014).]
GodSend
Report this Post05-17-2014 05:44 PM Click Here to See the Profile for GodSendSend a Private Message to GodSendEdit/Delete MessageReply w/QuoteDirect Link to This Post
Optional 86-88
RPO codes
U63- AM (84-87)
Poster was suggesting that STOCK != OPTIONAL.
