  New Wiring into the Door Tips
New Wiring into the Door Tips by Sourmug
Started on: 05-06-2014 10:57 PM
Replies: 2 (203 views)
Last post by: Sourmug on 05-06-2014 11:38 PM
Sourmug
Total ratings: 144
Report this Post05-06-2014 10:57 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
All:
Please share your tips for running some new wires from the cabin, through the rubber conduit and into the door.
I'm having a heck if time trying to get something, anything though that blasted crinkled conduit.
Thanks
[This message has been edited by Sourmug (edited 05-06-2014).]
cmechmann
Report this Post05-06-2014 11:11 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
With or without the door panels off. And how much wire are you installing.
From the inside, with the side cover off under the dash, take a coat hanger and make a small(less than 1/4") loop at the end. Important to have a complete loop so it doesn't snag stuff. Fish the hanger through the rubber tube. Use your fingers to feel it and bend it as it goes through. You want to keep it away from the other wires. Once you are in the door you can put your new wires in the loop and pull them back through.
Word of caution. The door window wires have a habit of getting a break right inside the tube. I find it sometimes needs to have the tube pushed off the body from the inside and from the door so you can see the wires if they are broken. That will require the door panel completely off to do it right.
[This message has been edited by cmechmann (edited 05-06-2014).]
Sourmug
Total ratings: 144
Report this Post05-06-2014 11:38 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for your response.
Inner door panels are off, I'll try the coat hanger, the wire I was using to fish probably isn't heavy enough.
Nolan
