  Last major issue
Last major issue by Zeak
Started on: 05-06-2014 04:17 PM
Replies: 11 (222 views)
Last post by: Csjag on 05-08-2014 10:23 PM
Zeak
Report this Post05-06-2014 04:17 PM Click Here to See the Profile for ZeakSend a Private Message to ZeakEdit/Delete MessageReply w/QuoteDirect Link to This Post
I tried asking on some of the FB pages because I hate to pester you all with the simpler questions.
I have an 88 with the 2.5/ isuzu 5 speed.
Replaced the rear main.
New oil pan and gasket.
New timing cover and gasket.
New valve cover gasket (3rd one finally worked)
Replaced the dipstick o-rings.
New oil pressure sending unit.
These are all things that needed to be replaced anyway as they where old and dry rotted.
I'm still getting a major oil leak from the starter area. I dropped it down and could not find where it was coming from.
Please help....
1988 Fiero 2.5
Midn1ght Driv3r
Report this Post05-06-2014 04:34 PM Click Here to See the Profile for Midn1ght Driv3rSend a Private Message to Midn1ght Driv3rEdit/Delete MessageReply w/QuoteDirect Link to This Post
What about the camshaft seal/cover above the rear main?
Lou6t4gto
Report this Post05-06-2014 04:42 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
doesn't the 2.5 have a "side cover seal" where the lifters are ?
Csjag
Report this Post05-06-2014 05:22 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes it does
Zeak
Report this Post05-06-2014 05:52 PM Click Here to See the Profile for ZeakSend a Private Message to ZeakEdit/Delete MessageReply w/QuoteDirect Link to This Post
The cam cover was clean when the trans was apart from the engine.
The lifter cover is on the other side of the engine, but is also dry.
Csjag
Report this Post05-06-2014 06:25 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you checked the oil pressure sending unit?
Zeak
Report this Post05-07-2014 12:51 PM Click Here to See the Profile for ZeakSend a Private Message to ZeakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, I replaced it with a new one. The old one was cracked and leaking a little.
Custom2M4
Total ratings: 114
Report this Post05-07-2014 01:00 PM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did you coat the threads with a sealant?
Csjag
Report this Post05-07-2014 01:38 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also check to see that the oil filter is not leaking, I know its on the other side but oil can drip under and over.
Zeak
Report this Post05-07-2014 03:07 PM Click Here to See the Profile for ZeakSend a Private Message to ZeakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes to the sending unit threads.
On the 88 2.5, they built the oil filter right into the oil pan.
That's where the oil pump and balancer assembly is.
The only oil in that area seems to be blown there by the passing wind.
Has any one tried leak dye in there oil? I'm out of ideas now....
tebailey
Report this Post05-07-2014 03:44 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've used the dye on a lot of machines, works great for chasing down those pesky little leaks that you can't find the source of.
Csjag
Report this Post05-08-2014 10:23 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you back it up on ramps and let it idle while you look to see where the oil is being forced out?
