  Isuzu 5spd shift cable adjustment/install
Isuzu 5spd shift cable adjustment/install by Amos 8833
Started on: 05-05-2014 05:39 PM
Replies: 10 (737 views)
Last post by: Amos 8833 on 05-08-2014 11:37 AM
Amos 8833
Report this Post05-05-2014 05:39 PM Click Here to See the Profile for Amos 8833Click Here to visit Amos 8833's HomePageSend a Private Message to Amos 8833Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am having a time getting the shift cables installed and adjusted; suggestions please.
Amos 8833
Amos
NW-Fiero
Report this Post05-05-2014 06:47 PM Click Here to See the Profile for NW-FieroSend a Private Message to NW-FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
New cables 5 speed, new transmission install from 4 speed?
Engine/Model/year vehicle?
A little bit more info please
Mark
' 85 2m6 3.4PR
In the Great Northwest!
[This message has been edited by NW-Fiero (edited 05-05-2014).]
Amos 8833
Report this Post05-05-2014 08:00 PM Click Here to See the Profile for Amos 8833Click Here to visit Amos 8833's HomePageSend a Private Message to Amos 8833Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi
Thanks for the response. The car is a 87 4cyl, 5spd Isuzu. I am in the process installing a 3800. I have installed the motor and am in the process of installing new shift cables. I have located the shift lever timing holes and installed pins to lock the shift leve My problem is that I do not know the proper location of the two trans levers in relationship to pinned shift lever position. I have disconnected the shift cables from the tranny lever. Now, in which location should the levers on the tranny be when I attach the cables to the tranny?
Thanks
amos
Bloozberry
Total ratings: 311
Report this Post05-05-2014 08:25 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's pretty easy to figure out with a helper. First have a look at the two levers and notice that one of them causes the shift shaft at the transmission to either push further into or pull out of the transmission case and the other rotates the shaft. The first thing you have to do is grab the lever that makes the shaft rotate and place it in the middle of the three possible positions. Once it's in the middle position the shaft will automatically pop into or out of the transmission and settle at the middle depth position as well.
Once you've found that spot, that's equivalent to having the console shifter in neutral between the 3-4 shift gate. So now you have to figure out which way to turn the rotating shaft so the transmission goes into 3rd. The best way to describe how to figure that out is to have a helper sit in the car and simply move the in-car shifter fore and aft while watching one of the cables in the engine bay move. When your helper pushes the shifter forward (as if he were shifting from neutral to 3rd) one of the cables should stick further out. Now just imagine if that cable were attached to the lever that rotates the shaft. Grab that lever and rotate it in the same direction as the cable would push it, just make sure not to push down or pull up on the shaft at the same time. Once you've done that, the transmission is in 3rd gear so you can reattach the cables to the levers with the guide pin in place and tighten them.
Report this Post05-05-2014 09:15 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The top lever should be up and to the rear. That puts it into First Gear, the position of the shifter. You can move the top lever forward and backward to find the neutral gate. Once you do, lift up on it then push it back toward the rear bumper. It should click into position of First Gear. Insert the cable end ball stud and tighten.
Amos 8833
Report this Post05-06-2014 03:33 PM Click Here to See the Profile for Amos 8833Click Here to visit Amos 8833's HomePageSend a Private Message to Amos 8833Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello many thanks for the shifter cable note. Of the two levers on the tranny the top one rotates from it's pivot front to rear and has 3 stop points and is located on the driver side. Should this lever be rotated fully to the rear of the car? The other lever rotates up and down, is under spring tension and is located more on the engine side of the tranny. I can't detect any notch points with lever or possible locating point.
Any help will be greatly appreciated.
Thanks
Amos
Amos
Report this Post05-06-2014 04:12 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The smaller of the cables is the selector cable. It operates when you move the shifter side to side. It operates the lever under spring tension. That selects the 3 gates; 1-2, 3-4, and 5-R. Each of those 3 gates has N in between them. That's the center click you feel in the other lever.
Leave the cable nearest the driver, inside the shift console attached to the shifter when you are installing the lock pin. Also leave it attached at the transmission end. Then move the other lever on the transmission downward toward the back of the car. Let it click into it's position and install the remaining cable. Sorry for the confusion. I was originally thinking of one of the other transmissions.
Isuzu cables and levers
Report this Post05-06-2014 04:13 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Jan 2002
double post deleted
[This message has been edited by fierofool (edited 05-06-2014).]
Amos 8833
Report this Post05-07-2014 08:26 PM Click Here to See the Profile for Amos 8833Click Here to visit Amos 8833's HomePageSend a Private Message to Amos 8833Edit/Delete MessageReply w/QuoteDirect Link to This Post
Many thanks for your help?
Amos
Amos
Report this Post05-07-2014 08:54 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Was it productive? Any results?
Amos 8833
Report this Post05-08-2014 11:37 AM Click Here to See the Profile for Amos 8833Click Here to visit Amos 8833's HomePageSend a Private Message to Amos 8833Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have been out of town, will be working on the car this afternoon. I will let you know how it goes.
Amos
Amos
