  tire sizes im going insane, what gives?
tire sizes im going insane, what gives? by lordbg0205
Started on: 05-04-2014 07:05 PM
Replies: 4 (314 views)
Last post by: FieroBobo on 05-06-2014 02:59 PM
lordbg0205
Report this Post05-04-2014 07:05 PM Click Here to See the Profile for lordbg0205Send a Private Message to lordbg0205Edit/Delete MessageReply w/QuoteDirect Link to This Post
So i have been in pursuit of the perfect rims for about a year. I want a set of kyowa racing 18x8. Offset 35mm. For an 87 gt. I have been through all the calculators the diagrams blah blah. I want 215 40/r18 in front and 225 40/r18 in back. Im lowered on springs 1"and will go lower once the rims are on the car to get a good stance. Im i being too picky with the 215's in front, will 225's rub or stick out. I just dont want them hanging out there, i know its only like a .25" on each side of the tire thing, but i dont want one of those skateboard cars where the rims hang out.
Fadingaway
Report this Post05-04-2014 11:01 PM Click Here to See the Profile for FadingawaySend a Private Message to FadingawayEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had some 18x7s with 235 40 in the rear and 225 35 front with a 37mm offset, no poking or rubbing on stock height. The front rubbing might be your issue if you have too much sidewall so I would say nothing bigger than a 245 in the rear or 225 40 in the front with that offset
jb1
Report this Post05-05-2014 12:14 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have 18x7.5 (+38mm) on front with 225/40/18 and rear is 18x8.75(+35mm) with 265/35/18
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a---sold
Northstar Rebuild
KurtAKX
Total ratings: 128
Report this Post05-05-2014 04:47 PM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
10mm section width is pretty small. Are you sure it's worth giving up the ability to rotate the tires for a difference that's trivially small?
FieroBobo
Report this Post05-06-2014 02:59 PM Click Here to See the Profile for FieroBoboSend a Private Message to FieroBoboEdit/Delete MessageReply w/QuoteDirect Link to This Post
You are right about that.
10mm = .394" Remember .375" = 3/8"
10mm / 25.4mm/in = .3937in.
On the other hand, staggered tire sizes can help to improve a Fiero's handling. Ideally, you want the tire widths, front-back, to match the Fiero's front-rear weight distribution, roughly 44% / 56%.
~ Bob ~
