  Upgrade to bad fuel pump on stock V6 for upgrade later?
Upgrade to bad fuel pump on stock V6 for upgrade later? by MulletproofMonk
Started on: 05-04-2014 05:24 AM
Replies: 11 (445 views)
Last post by: Dr.CGT on 05-06-2014 08:46 AM
MulletproofMonk
Total ratings: 78
Report this Post05-04-2014 05:24 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I am picking up a car next week that needs a fuel pump. I'm looking for fuel efficiency, so I'm trying to decide if I want to do a 3800na motor swap on the car or maybe just look for a 4T60 with a 2.84 final drive ratio to put with the 2.8L...
So if I do a motor swap, I am going to need to upgrade the fuel pump and was wondering if swapping in the AC Delco EP-381 now is a bad idea. Will putting a EP-381 use more gas, flood the motor, etc?
The price difference between the Fiero Fuel Pump and the EP-381 at RockAuto is only $3.00-$4.00. I don't mind spending that if I don't end up upgrading the motor (and the EP-381 won't hurt anything), but I hate to spend $60+ on a fuel pump just to pull it out and throw it away... Also why does the 88 run a different fuel pump?
86 Fiero, ACDELCO Part # EP240 More Info {#25116162} GM Original Equipment $61.79
88 Fiero, ACDELCO Part # EP378 More Info {#25163468} GM Original Equipment, requires strainer 25121637 $62.79
Syclone, ACDELCO Part # EP381 More Info {#25163473} GM Original Equipment; does not include a strainer. $65.79
-Brian
Removing the roof panel
My HUD install thread
Modified stock air canister and base to 3.5 inch for 3800na
Total ratings: 207
Report this Post05-04-2014 06:12 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The stock v6 fuel pump runs a 4.9, it will run a N/A 3800 unless you turbo....
sardonyx247
Total ratings: 219
Report this Post05-04-2014 07:48 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
The 381 just is capable of more pressure, your regulator will bring it down to stock Fiero levels.
So you will have no problem.
I just put one in a 3.4L, pressure is normal. Seems to run fine.
I used the airtex pump, not the AC Delco, but the results will be the same, (you know Delco is now made in china too)
"DRIVE IT LIKE A FIERO"
'87 Quad 4 H.O.
Blacktree
Total ratings: 350
Report this Post05-04-2014 10:11 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just out of curiosity, how much pressure can the EP381 pump handle?
notaguru
Report this Post05-04-2014 06:33 PM Click Here to See the Profile for notaguruClick Here to visit notaguru's HomePageSend a Private Message to notaguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since you'll be in there anyway, you'll have a chance to upgrade wiring to the fuel pump, and to refresh all connections. I use 10-gauge wire on my cars, with all soldered connections. I'll usually run the 10ga to the battery supply (via a fuse or fusible link), interrupting that direct circuit with a relay powered by the original circuit. Back in my Grand National days, that made a 2V difference at the pump!
Also, the Fiero fuel level sender was designed by the same GM maniac who did the dew wipes. It might make sense to replace the 0-90 ohm sender, and there's a good one on eBay for $22 shipped!
So if the tank's coming down anyway, think about optimization...
MulletproofMonk
Total ratings: 78
Report this Post05-04-2014 08:18 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why does the 88 use a different part number? Does is have higher pressure? Should I use that one?
-Brian
[This message has been edited by MulletproofMonk (edited 05-04-2014).]
Total ratings: 207
Report this Post05-04-2014 08:32 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure, but the one pump does not include the strainer....
sardonyx247
Total ratings: 219
Report this Post05-05-2014 07:08 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
None of them come with strainers.
Here lets make this EASY
http://www.ebay.com/itm/NEW...&vxp=mtr#ht_63wt_867
An old stock one, made in the USA
still need a strainer.
'87 Quad 4 H.O.
MulletproofMonk
Total ratings: 78
Report this Post05-05-2014 05:32 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks sardonyx247. Point taken. $30 is cheaper then the Airtex at RockAuto...
I ordered the strainer from RockAuto and almost ordered the wrong one (Fiero TS1 instead of Typhoon TS7).
5% off rockauto with code: 2109224018966383
mitchjl22
Report this Post05-06-2014 01:51 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
To answer the OP... I planned on a 3800 swap and ran an EP381 on my 2.8 for a few months... no problems.
-Mitch
sardonyx247
Total ratings: 219
Report this Post05-06-2014 02:33 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
I know, $30 is even cheaper than the airtex I found at $41, So I posted the Delco, as it is a "made in the USA' one still.
On a side note too, the airtex for the stock Fiero is a universal and supports ALOT of the higher HP cars, including the Buick GN.
Dr.CGT
Report this Post05-06-2014 08:46 AM Click Here to See the Profile for Dr.CGTSend a Private Message to Dr.CGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
You may need to change the in tank wiring to match the pump on 84-86
