  Fiero Store door insulation
Fiero Store door insulation by Rsvl-Rider
Started on: 05-04-2014 12:02 AM
Replies: 4 (343 views)
Last post by: Fishogs 84 on 05-04-2014 09:20 AM
Rsvl-Rider
Report this Post05-04-2014 12:02 AM Click Here to See the Profile for Rsvl-RiderSend a Private Message to Rsvl-RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero Store carries two inner door insulation products. One they call "jute" which looks like heavy felt for noise and drafts insulation. The other is a waterproof mylar shield which they indicate was original equipment. I haven't pulled my doors apart yet but I plan to very soon in order to install new dew wipes and felt window guides. Anyone know if both were used together from the factory or is it a choice between one or the other? Assuming they have never been replaced before should I expect to replace one or both of these at this time? Since it's my daily driver I would rather not tear the doors apart only to find there are other wear parts I should have been prepared to replace.
http://www.fierostore.com/P...spx?s=57660&d=83&p=1
http://www.fierostore.com/P...spx?s=57661&d=83&p=1
My rides...
1988 GT with a 3.4L V6 automatic
2006 Harley Sportster
'cause I love the twisties on two wheels or four.
jonathan2014
Report this Post05-04-2014 12:22 AM Click Here to See the Profile for jonathan2014Send a Private Message to jonathan2014Edit/Delete MessageReply w/QuoteDirect Link to This Post
they were both factory. this onehttp://www.fierostore.com/P...spx?s=57660&d=83&p=1 was glued to the inside of the door panel originally the other one was a thin piece of paper that was attached To door itself.
Sourmug
Total ratings: 144
Report this Post05-04-2014 01:16 AM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, it was paper attached to the doo with jute attached to the door panel
84fiero123
Total ratings: 325
Report this Post05-04-2014 09:06 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ayup, when I was utility at GM those jobs I did and he is absolutely right, we got the door pads from the supplier and in the case where it had electric windows we would put the door pad on a machine to punch a square hole, I didn't build Fieros our plant did cutlass's and others so the door pads had the electric window buttons in the door pad. but back to the insulation, it gets glued onto the door pad as shown and the paper goes on the door itself. we had a ribbon type glue that we had to put on the paper and a hot melt type glue gun we spread on the jute type insulation. the paper is to keep water off the other insulation and that jute is for sound deadening.
Steve
[This message has been edited by 84fiero123 (edited 05-04-2014).]
Fishogs 84
Report this Post05-04-2014 09:20 AM Click Here to See the Profile for Fishogs 84Send a Private Message to Fishogs 84Edit/Delete MessageReply w/QuoteDirect Link to This Post
Have you looked at Mighty Mat? It's a foil back insulation that has great insulation and sound deadening properties. I'm using it on the firewall of my '87 GT, & it works so well my wife wants it installed on her '88. You can get it in a variety of thicknesses for what you need. I used the 1/4" thick on mine.
With A Cutting Torch and Welder ANYTHING is Possible!!
'87 GT Black
'88 GT Neochrome
'87 GT Burgundy
