  Manual Shift Boot
Manual Shift Boot by fiero5150
Started on: 05-03-2014 01:47 PM
Replies: 2 (114 views)
Last post by: Rodney on 05-03-2014 05:19 PM
fiero5150
Report this Post05-03-2014 01:47 PM Click Here to See the Profile for fiero5150Send a Private Message to fiero5150Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am replacing the Shift Boot but it will not remain anchored in place. The plastic posts that go into the holes in the shift assembly are a smaller diameter than the holes (the original boot is identical). Thus, the boot comes loose when the shifter is moved. What is used to hold the boot in place? Thanks.
hiwil88formula
Report this Post05-03-2014 02:46 PM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not sure about the factory ones anymore, but I believe there is supposed to be a couple of nuts on the bottom to secure the ring. Rodney Dickman sells a replacement ring if you need one.
Rodney
Total ratings: 267
Report this Post05-03-2014 05:19 PM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The boot is secured with a couple of those sheet metal nuts that make their own threads as you thread them on. You might find some in the help section or Napa?
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
