  What size are the front swaybar bolts? . .?
What size are the front swaybar bolts? . .? by Custom2M4
Started on: 05-02-2014 01:06 AM
Replies: 8 (468 views)
Last post by: Blacktree on 05-10-2014 09:45 AM
Custom2M4
Total ratings: 114
Report this Post05-02-2014 01:06 AM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey all,
I moved not that long ago and misplaced my swaybar bolts in the move. What' size are those bloody things. It's the four that mount the swaybar to the frame.
I did a search and found an answer M8 x 1.25... Went to the bolt store, purchased these lots and they are too small. Anyone know if the size went larger for 87?
I'm guessing they are M10x1.25 but the store is a 10$ minimum and I don't want to keep making that trip and wasting 10$ on bolts every time.
Thanks
Bloozberry
Total ratings: 311
Report this Post05-02-2014 07:41 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
According to the 22P, they should be M8 x 1.25 x 25 for '84 - '87's. Perhaps someone modified your car or perhaps you could double-check that the bolts you bought were actually M8's. I can check a parts car later today if no one else has chimed in by then.
Custom2M4
Total ratings: 114
Report this Post05-02-2014 10:49 AM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
What is the size for 88s? Maybe it's late year 87 or something? My car wants to accept a pretty large bolt, I tried a couple others from my parts bin to see the size and it's a pretty large bolt.
Thanks blooz
Edit. It's definitely not an m8. I sucked it up and got some M10 1.25 and it's the right size but Im not confident enough to torque them in, seems like it might be a 3/8 20 pitch... I'll scour my bolt bins and see if I'm right.... If anyone knows the 88 sizing I'd like to know. The nuts are definitely factory as well.
[This message has been edited by Custom2M4 (edited 05-02-2014).]
Report this Post05-03-2014 02:13 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know about the size of the actual bolts, but the front sway bar (and entire suspension) on an '88 is totally different than what was used from '84-'87.
[This message has been edited by Patrick (edited 05-03-2014).]
Blacktree
Total ratings: 350
Report this Post05-03-2014 10:01 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the bolt threads all the way in, then it's the right size. If the holes were tapped for 3/8"-20 thread, the bolt would bind up after a couple turns.
That said, it's pretty common for the stock sway bar bolts to break. It's also common for people to drill & tap the bolt holes for a larger size. I ended up doing that with mine, because 2 of those bolts broke.
[This message has been edited by Blacktree (edited 05-03-2014).]
fierogt28
Report this Post05-03-2014 11:58 AM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
I thought all suspension bolts on the fiero are sized metric.
For 88s, that's a fact.
Correct me if I'm wrong...
fierogt28
88 GT, Loaded, 5-speed.
Custom2M4
Total ratings: 114
Report this Post05-03-2014 06:16 PM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, they bind after a couple turns, this is why I'm asking the question. I dont want to torque them if they arent metric. The car is also rust free, low km. I would highly doubt they are anything but factory installed bolts and nuts.
I've found several imperial bolts on the fiero, and since the nuts are awkward to get at, I don't want to install the wrong hardware.
Thanks for the help everyone. If I don't get an answer I might see if a tap will give me the size.
Report this Post05-09-2014 01:18 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was messing with the front sway bar on my '88 Formula today. The four mounting bolts are M8x1.25
[This message has been edited by Patrick (edited 05-09-2014).]
Blacktree
Total ratings: 350
Report this Post05-10-2014 09:45 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The original front sway bar bolts on my '87 SE were also 8mm. But as mentioned above, two of them broke when I tried to remove them. So I drilled & tapped the holes to 3/8", and got some SAE Grade 8 bolts.
Chances are the previous owner of Custom2M4's car did something similar.
