  fuel gauge electrical question
fuel gauge electrical question by fierofan25
Started on: 05-01-2014 03:42 PM
Replies: 2 (486 views)
Last post by: phonedawgz on 05-01-2014 06:55 PM
fierofan25
Report this Post05-01-2014 03:42 PM Click Here to See the Profile for fierofan25Send a Private Message to fierofan25Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have something in the works, But I need to know how to make a fuel sending unit that reads 40 ohm to 250 ohm to work with the fiero gauge. Like maybe a resister in the wiring. Thanks
electrical
seajai
Total ratings: 51
Report this Post05-01-2014 06:13 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero sender is 0-90 ohms, if the one you have now goes from 40-250 ohms, it's already out of spec and adding a resistor will only make it further out of spec. The resistance is a function of the windings, so unless the one you have has a resistor soldered into the circuit that you can remove, it wont work.
Total ratings: 290
Report this Post05-01-2014 06:55 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
You could do it with an Arduino.
