  Subaru WRX/Impreza vs Fiero Suspension
Subaru WRX/Impreza vs Fiero Suspension by GTPatrick
Started on: 04-28-2014 05:14 PM
Replies: 1 (198 views)
Last post by: fieroguru on 04-28-2014 05:54 PM
GTPatrick
Report this Post04-28-2014 05:14 PM Click Here to See the Profile for GTPatrickSend a Private Message to GTPatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Folks , correct if I'm wrong here but with the Fiero wheel studs being a 5x100 design and the Subaru WRX/Impreza wheel being a 5x100 design , I think but maybe wrong . Has anyone ever thought of investigating using the wheel hub from the wrx/impreza in place of the fiero wheel hub due to the fact that the wrx/I wheel hub bearings are stronger and have a large aftermarket for race competition/rallying than the fiero has or ever had ?
Any thoughts or opinions on this idea being doable or undoable ?
Cheers .
GTP
Report this Post04-28-2014 05:54 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are a few issues.
The WRX flange offset is higher, so the wheels will be pushed out further and could lead to brake fitment issues.
The mounting bolt pattern is 4 bolts vs. 3 so the upright will need some new holes machined.
The rear pilot diameter is larger, so the Fiero upright will need to be bored to accept it.
Fiero rear wheel bearing:
WRX front wheel bearing:
