Update System
  cv axle
cv axle
by sgosser
Started on: 04-27-2014 12:11 PM
Replies: 7 (170 views)
Last post by: sgosser on 04-27-2014 03:20 PM
sgosser
Report this Post Click Here to See the Profile for sgosserClick Here to Email sgosserSend a Private Message to sgosserEdit/Delete MessageReply w/QuoteDirect Link to This Post
While I had the back of the car jacked up I checked to see if there was any play in the wheels, both sides I can move up and down between half inch and an inch, ball joints are good, it seems to be in the hub or cv axles, I was wondering how concerned I should be and the next step in looking at it. it is a new to me 2.8 4 speed, that was a daily driver for someone. thanks
scott
Scott
85 gt
Report this Post Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wheel bearings loose? That is too much slop to be safe.
[This message has been edited by Gall757 (edited 04-27-2014).]
Custom2M4
Total ratings: 114
Report this Post Click Here to See the Profile for Custom2M4Click Here to Email Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Does it move side to side or vertical? I would be looking at the strut if it's vertical.
Or the control arm bushings.
[This message has been edited by Custom2M4 (edited 04-27-2014).]
sgosser
I believe it moves vertical only. mechanic friend came by but did not have time to look close. he said he couldn't tell yet where it is coming from but that it wasn't ball joints. It is storming bad here right now or I would go check it again. I am pretty sure it will move vertical only. It seems to be something internal. The struts don't move at all but the movement up and down is moving inside the axle boots I think or maybe in the hub. I am not sure. thanks
Blacktree
Total ratings: 350
Report this Post Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageClick Here to Email BlacktreeSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The rear bearing/hub unit is the anchor point for both the wheel and the outer end of the CV axle. If it's bad, then the wheel will be able to wiggle in every direction. And the CV axle will wiggle along with it.
If the ball joint is bad, then the entire wheel/hub/knuckle assembly will move back and forth as a unit.
If the toe link is bad, then the wheel will wiggle left to right, but not up and down.
Sounds to me like the bearing/hub unit is bad. But if it's bad enough to let the wheel wiggle over 1/2", then it should also be making some pretty scary noises when you drive it. And the back end will float around. This is a MAJOR safety issue. Because if the bearing/hub unit comes apart, the wheel can literally come off the car.
[This message has been edited by Blacktree (edited 04-27-2014).]
sgosser
that sounds bad. I haven't driven it yet so I can not confirm any behavior. The whole cradle, engine, trans I bought from an 87 and installed in my 85. just got it hooked up. I guess my first inspection should be of the hub. thanks
Total ratings: 204
Report this Post Click Here to See the Profile for olejoedadClick Here to Email olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are the nuts on the ends of the axles?
sgosser
yep. everything is on and tight.
