  Backfiring?
Backfiring? by tshark
Started on: 04-26-2014 03:56 PM
Replies: 3 (135 views)
Last post by: fiero2kewl on 04-28-2014 09:26 AM
tshark
Total ratings: 68
Report this Post04-26-2014 03:56 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post04-26-2014 06:10 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
2.8s tend to do this.....sort of a pop popata pop as you let off the gas between gears. It does not seem to hurt anything, and may be a combination of incomplete burning of fuel and timing and perhaps temperature. Injector cleaner added to the fuel may help.
edit: trying to remember what a water balloon popping sounded like....maybe you have broken a motor mount.
[This message has been edited by Gall757 (edited 04-26-2014).]
tshark
Total ratings: 68
Report this Post04-26-2014 07:56 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
fiero2kewl
Report this Post04-28-2014 09:26 AM Click Here to See the Profile for fiero2kewlSend a Private Message to fiero2kewlEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have had issues in the past it would back fire and then quit.... if you pump the gas pedal in neutral/park will it pop? If it does I would replace the ignition control module inside the distributor. when its starting to go bad it can cause backfiring and then straighten up and all seems fine. goodluck
