  Blew injector fuse - ran on 3 but now won't run at all
Blew injector fuse - ran on 3 but now won't run at all by DaveK1987V6
Started on: 04-25-2014 03:31 PM
Replies: 1 (109 views)
Last post by: phonedawgz on 04-25-2014 04:53 PM
DaveK1987V6
Report this Post04-25-2014 03:31 PM Click Here to See the Profile for DaveK1987V6Send a Private Message to DaveK1987V6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Stock V6 suddenly ran rough and I found a blown injector fuse - replaced, but blew again. Stupidly tried a 10 amp. Ran for about 5 miles then stalled and won't run at all now, not even on 3 - fuel pump is still supplying fuel. I've removed the plenum and checked the injectors - one has very low resistance so I guess that's the basic issue. I've ordered a new one. My concern is that it stopped running at all - could I have damaged the ECM by using the 10 amp fuse?
Will be removing the fuel rail over the next week or so to change the bad injector. Any help welcomed!!
Total ratings: 290
Report this Post04-25-2014 04:53 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep you could have.
