| quote | Originally posted by TbirdMarc:
Yep, Car has been sitting for 12 years. I sprayed some PB Blaster in the spark plug holes. I will let it sit for a few days and try again, if not will probably put a crate 3.4 in it. |
It may be wise to remove the O2 sensor before starting your engine. Screw a plug into the hole temporarily.
P-Blaster / ATF / Oil etc may foul the O2 and you'll wonder why the engine is running so bad. The "cat" may also get its share of contamination as well.
Spoon
