Update System
  Intermittent missing
by newfiejeff
Started on: 04-23-2014 05:13 PM
Replies: 20 (274 views)
Last post by: newfiejeff on 04-26-2014 07:37 PM
newfiejeff
Report this Post Click Here to See the Profile for newfiejeffClick Here to Email newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
1986 2m4
Where to start to look for an intermittent missing causing black smoke. I bought the car last fall and the ride home it was really bad for about 20 minutes out of a 2 hour ride then left her andit ran smooth after that. It came back again at a couple of odd times but left her hen I pulled over and raced it over a few times.
I am after replacing plugs,gas and air filter the winter.
You are probably going to tell me that I need the tank flushed. I am thinking it's dirt.
Bruce
Report this Post Click Here to See the Profile for BruceClick Here to Email BruceSend a Private Message to BruceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check your vacuum lines for any cracks.
newfiejeff
Done that any everything is good, it has a great idle, so lines are good.
newfiejeff
Would a sensor cause this problem?
Driving to work today going up the same hill as yesterday, the car started to smoke black and miss. I pushed in on the clutch and gave it a few shots of gas and then I went on best kind.
Report this Post Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
A bad CTS will usually make the engine run rich.
[This message has been edited by Gall757 (edited 04-24-2014).]
newfiejeff
Would it give trouble intermittent?
Maybe the sensor is OK and the wiring is not.
newfiejeff
Will check the wiring when I get home.
Seems pretty coincidental that it happened when going up the same hill. Could it be dirt/water moving in the tank and getting sucked up?
Anyone got the specs on testing of the sensor?
Total ratings: 570
Report this Post Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pull tach filter and leave it out till sure filter isn't the problem.
See my Cave, HE Ignition
newfiejeff
So you are saying that the filter could be the problem? My tach is not showing a true reading, maybe it's all related.
Total ratings: 182
Report this Post Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Not the gas tank, but change the fuel filter.
newfiejeff
Replying I meant the tach filter. I am after replacing the filter after I got the car which was only last fall and only got about 400 or 500 klms on it.
newfiejeff
The miss and black smoke happened on the way home again yesterday and a few shots of hard gas it was gone.
Came to work this morning and no issue at all.
I am thinking that there is ugly gremlins in the gas tank!!!!
Bloozberry
Total ratings: 311
Report this Post Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Black smoke is unburned fuel and a misfire is an indication your ignition isn't working properly. Pull the distributor cap off and make sure the pick up coil at the top doesn't look like this:
Also, make sure your PCV valve is working properly (it should rattle when shaken).
newfiejeff
I will check that this weekend and I know the PCV is fine.
But by me giving a couple of good shots of gas when its startS to miss it works fine after that, almost seems like its cleaning out some kind of dirt.
Would water in the gas also cause that trouble? If so what is the best to get water out of the tank?
The black smoke indicates excess fuel. That would happen if the spark did not fire for a few revolutions and then suddenly fired again. I doubt if water is your problem, but you can purchase an additive for the fuel tank that should take care of it. BTW, if your distributor looks half as bad as Bloozberry's picture, find another one.
Total ratings: 182
This is what my fuel filter clgged up was like.
You might have more than one issue, but if the fuel filter is old it needs replace anyway.
newfiejeff
Just checked the codes and a code 15 is what is showing
Bingo.....
newfiejeff
Just checked the sensor and the lock for the harness was broke. I bent the sensor leads a little and push the connector in and test drove it and it seemed fine. So I pushed the connector hard in and put tape around it. Maybe the cable was not making a good connection all the time and that is why it was it intermittent and when I revved it over it seemed to help.
Is this wishful thinking....lol
Raining too much to fully check
[This message has been edited by newfiejeff (edited 04-25-2014).]
newfiejeff
Update
Must have been a slack sensor connector. I took the car for some gas and a good run it ran perfect and it idles the best it ever did. Would the cts affect the idling?
Thanks again for all who helped!!!!
