  who makes the 3800 speedometer converter
who makes the 3800 speedometer converter by fierofan25
Started on: 04-23-2014 11:52 AM
Replies: 17 (610 views)
Last post by: mitchjl22 on 07-18-2014 11:28 PM
fierofan25
Report this Post04-23-2014 11:52 AM Click Here to See the Profile for fierofan25Send a Private Message to fierofan25Edit/Delete MessageReply w/QuoteDirect Link to This Post
One of the last things I need for my swap is the speedometer converter to make my speedometer work. Is anyone selling them. I know they are easy to make but I would rather just buy one.Thanks
Total ratings: 207
Report this Post04-23-2014 12:05 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you can solder the circuit into your harness following some simple instructions, I can make the circuit for you.
Send me a PM if you are interested.
Purple86GT
Total ratings: 62
Report this Post04-23-2014 12:10 PM Click Here to See the Profile for Purple86GTSend a Private Message to Purple86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can do it for you. Not looking to get ritch.. Just making mine and I may as well make a few more. Maybe $10 plus postage?
Cheers!
Lou6t4gto
Report this Post04-23-2014 01:03 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I "THINK" I got mine from Phonedawgz
bomluuk
Report this Post04-23-2014 01:10 PM Click Here to See the Profile for bomluukSend a Private Message to bomluukEdit/Delete MessageReply w/QuoteDirect Link to This Post
If this is what you're talking about, its the third item down.
http://www.reddevilriver.com/Related_Products.html
Purple86GT
Total ratings: 62
Report this Post04-23-2014 02:36 PM Click Here to See the Profile for Purple86GTSend a Private Message to Purple86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just put one together for $hits and giggles at work.
I didn't have a 22K resistor so I used a 24K... Not sure how much of an impact (if any) this would have... I will get the actual 22K resistors for my final ones.. Then epoxy and shrink tube them into a small tab with 3 leeds.
FIEROFLYER
Total ratings: 180
Report this Post04-23-2014 06:38 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
I build them right into the harness at the C203 connector on my harnesses to make things easier. But yes they are very simple to make and cost very little for the components to make one. Dan
djlamp14
Report this Post04-23-2014 08:55 PM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
thought you can just change the CPPR, (calculated pulses per revolution) on the tune and your set? Fiero needed something lower than what a 4t65e puts out.
11.8@115mph 1/4 mile 1999 Regal GSX being demodded for swap into a 87 Fiero GT.
11 sec pass>>http://www.youtube.com/watch?v=SQT4X2eBlR8
Total ratings: 291
Report this Post04-23-2014 09:27 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes you do have to sent the PCM for the correct PPM. You also have to use the 'buffer' circuit to convert the square wave output of the PCM into a sine wave for the Fiero speedo.
djlamp14
Report this Post04-23-2014 09:44 PM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ah missed that bit somewhere. Anyone have a little solder in vss harness that they want to sell?
Total ratings: 291
Report this Post04-24-2014 01:28 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you talking about the PCM to speedo buffer? If yes - then third item down. - http://www.reddevilriver.com/Related_Products.html
Or are you talking about the VSS to PCM wire? I can supply either the weatherpack Fiero one (usually used when using the stock Fiero MT) or the metripack one (used on the 4T60E/4T65E/newer non-Fiero MTs)
mitchjl22
Report this Post04-24-2014 01:47 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM Sent
djlamp14
Report this Post04-24-2014 01:31 PM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm swapping in a 3800 with a 4t65e hd into a 87 fiero gt 2.8 5 speed. I need to install that wire in series with the vss wire then or elsewhere.
Total ratings: 291
Report this Post04-24-2014 03:34 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes if you are making your own harness. Usually is included on a pre made harness. On the harnesses I make I put them in the harness between the PCM and C203
[This message has been edited by phonedawgz (edited 04-24-2014).]
djlamp14
Report this Post04-25-2014 12:35 AM Click Here to See the Profile for djlamp14Send a Private Message to djlamp14Edit/Delete MessageReply w/QuoteDirect Link to This Post
You have a wire in piece that you want to sell?
Total ratings: 291
Report this Post04-25-2014 03:31 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
bomluuk
Report this Post05-02-2014 01:10 PM Click Here to See the Profile for bomluukSend a Private Message to bomluukEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just had to point this out:
Yes its the third item down.
mitchjl22
Report this Post07-18-2014 11:28 PM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
Where do I find the buffer circuit on Timm's site? Jk I like being a smart ass. I just ordered one.
-Mitch
[This message has been edited by mitchjl22 (edited 07-18-2014).]
