  What is the rolling weight of an 86GT?
What is the rolling weight of an 86GT? by Purple86GT
Started on: 04-22-2014 06:51 PM
Replies: 1 (275 views)
Last post by: fierofool on 04-22-2014 07:50 PM
Purple86GT
Total ratings: 62
Report this Post04-22-2014 06:51 PM Click Here to See the Profile for Purple86GTSend a Private Message to Purple86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
86 GT, no engine or trans. I want to know if a 1800lb hitch mount winch can pull my GT up a car hauler.
Thanks!
Report this Post04-22-2014 07:50 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The curb weight of the car is about 2800 lbs. The engine and trans don't weight 1000 lbs, so with that you would be a little over the 1800 lb winch load. Now, take into consideration that you're not lifting the car, but moving it up an incline that's probably not more than 45 degrees. The 1800 lb winch isn't maxed out at 1800 lbs. It will have some reserve. Probably 40-50% as most lifting devices have. You should be safe.
BTW, if you plan to use this vehicle in the future, DO NOT move the vehicle without axle stubs in place. You will destroy the rear hub bearings.
