  How to remove 88 front upper control arm shafts
How to remove 88 front upper control arm shafts by the99camaro
Started on: 04-21-2014 06:38 PM
Replies: 5 (794 views)
Last post by: the99camaro on 04-21-2014 10:42 PM
the99camaro
Report this Post04-21-2014 06:38 PM Click Here to See the Profile for the99camaroSend a Private Message to the99camaroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I might being having a moment or something but for the life of me I can't see how the shafts come out. I'm in the process of replacing all my bushings and it's in my way please someone help thank you.
[This message has been edited by the99camaro (edited 04-21-2014).]
Report this Post04-21-2014 07:13 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have to remove the bushing and sleeve from the right hand side of the picture. Then the cross shaft will slide far enough to the right for the left hand portion to clear the bushing. Then you can pull the shaft out to the left.
If you are just swapping to poly bushings, heat the edge of the sleeve until the bushings pop out (it will pop out in a flaming ball of rubber, so plan accordingly). Then clean and install the poly ones. No need to remove the cross shaft.
Bloozberry
Total ratings: 311
Report this Post04-21-2014 07:14 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have to remove the bushing on the right side of your photo, slide the shaft part way through the right hand bushing hole until you can remove the large washer on the left hand side of the shaft, then remove the left hand bushing and pull the shaft out from the left hand bushing hole.
Edit: rats... that damned guru guy beat me to the punch!
[This message has been edited by Bloozberry (edited 04-21-2014).]
mrfiero
Total ratings: 150
Report this Post04-21-2014 07:15 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is how I do it.......first, remove the nuts & washers from both ends. Next, burn out the old rubber bushings. With the bushings out of the way you can push the shaft through (from left to right) and remove it completely. Once the shaft is out of the way you can press out the bushing sleeve (unless you plan in installing poly bushings). Be careful when pressing out the sleeves.....the UCA is easily bent.
the99camaro
Report this Post04-21-2014 07:38 PM Click Here to See the Profile for the99camaroSend a Private Message to the99camaroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys, I'm going with rubber, so no need to be gentle lol
the99camaro
Report this Post04-21-2014 10:42 PM Click Here to See the Profile for the99camaroSend a Private Message to the99camaroEdit/Delete MessageReply w/QuoteDirect Link to This Post
the99camaro
Member since Jan 2013
