  Installing new brake pads
Installing new brake pads by Lou and Blue
Started on: 04-16-2014 01:32 PM
Replies: 4 (166 views)
Last post by: David Hambleton on 04-16-2014 02:30 PM
Lou and Blue
Report this Post04-16-2014 01:32 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm planning on putting new brake pads in my 85GT. Everything is stock. I have replaced brake pads in the past (sometimes with squeak issues afterward though) and I'm concerned about the need to twist and compress the rear calipers at the same time.
Any info on how to do this would be helpful. Thank you!
Louis Duet
Baldwin, Long Island, NY
Where driving hard is SOP.
"Blue" <= '85 Fiero GT
Stock V6---Stock everything. Trying to keep it 'mostly' that way.
"Boo" <= '81 Delorean DMC-12
The "DuetLorean"
VIN #5835
Stock PRV engine
Robertson Equipped
Neiland/Delman Engineered
Carbed and loving it! (Peugot 604 manifold) ---"Sorry purists"
jpeeler
Report this Post04-16-2014 01:45 PM Click Here to See the Profile for jpeelerSend a Private Message to jpeelerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I followed the Ogres advice and did not rotate the piston. Instead compressed them straight back. Good right up in the cave.
Lou and Blue
Report this Post04-16-2014 01:47 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, so the rears can just be compressed with a c-clamp without rotating them? That would be great.
Can you link me to the Ogre's info?
Thank you !
Louis Duet
The "DuetLorean"
VIN #5835
Stock PRV engine
Robertson Equipped
jpeeler
Report this Post04-16-2014 01:51 PM Click Here to See the Profile for jpeelerSend a Private Message to jpeelerEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://home.comcast.net/~fierocave/brakerear.htm
Just need a large c clamp and a socket over the screw on the back to allow it to spin.
[This message has been edited by jpeeler (edited 04-16-2014).]
David Hambleton
Report this Post04-16-2014 02:30 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you !
In between "Fiero Auctions" & "Real Time Chat" at the top of the screen.
