  Can't Make "Ratcheting" happen
Can't Make "Ratcheting" happen by 2kewlgypsy
Started on: 04-16-2014 11:09 AM
Replies: 1 (130 views)
Last post by: Lou6t4gto on 04-16-2014 01:16 PM
2kewlgypsy
Report this Post04-16-2014 11:09 AM Click Here to See the Profile for 2kewlgypsySend a Private Message to 2kewlgypsyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Read Ogre's Cave article on TV Cable adjustment, and my car has been sitting a long time, before going back on the road last week. Changing fluids, tune ups, ball joint replacements are all on the list, as well as new paint.
Thought this looked like an easy procedure "just to make sure its right" before dark last night.
Button is way hard to push in, but finally got it, and moved the slider - then moved the throttle linkage all the way open - no ratcheting. pushed the button all the way again, and moved the slider all the way the other way (in case I read it wrong, so now the piece that ratchets is all the way out, again with the linkage, and nothing happened. Set it to about where it was (according to the dirt stain), and it drove in fine this morning.
Not overly concerned about it, but do have a couple of questions: Is the button supposed to be that hard to push, and should I lube the pieces a bit to see if I can get it to ratchet?
Thanks y'all!
Dave
https://images.fiero.nl/2012/photo_(6)_4.JPG
Lou6t4gto
Report this Post04-16-2014 01:16 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
"Ain't Broke, DON'T fix it" !
