  GBCT difficult to shift into 1st
GBCT difficult to shift into 1st by johnyrottin
Started on: 04-16-2014 09:26 AM
Replies: 3 (202 views)
Last post by: Archie on 04-16-2014 02:51 PM
johnyrottin
Total ratings: 85
Report this Post04-16-2014 09:26 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
The GBCT is having difficulty shifting into 1st gear ever since the newly rebuilt 5 speed was installed by Whodeanie. Not looking for any finger pointing or blame here though. Trying to find out if there is any adjustment to the shift mechanism that I can explore to smooth things out.
tesmith66
Total ratings: 135
Report this Post04-16-2014 12:39 PM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Engine running or not? If it happens only with engine running, suspect clutch not fully disengaging (hydraulics, bent pedal, worn clutch shaft bushings, worn fork, etc.) If it happens engine running or not, could be shifter, cable, or possibly all of the above. Does it also happen in 3rd and 5th?
Sorry, probably only added to the confusion, but Fiero clutch systems are a pain. Every part in the system has to be in perfect working order.
1986 SE Aero coupe.
johnyrottin
Total ratings: 85
Report this Post04-16-2014 02:19 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can do a bit of investigating tonight but as I recall it is smooth in all gears, running or not, with the exception of first. Difficult into first running or not running.
Archie
Total ratings: 547
Report this Post04-16-2014 02:51 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
No telling with Dean, he may have just put the banjo on upside down.
Read #4 & start from there. http://v8archie.com/v8Archie/ToC6.htm
Archie
