  3800 swap alignment specs?
3800 swap alignment specs? by jknaack
Started on: 04-15-2014 10:47 PM
Replies: 4 (556 views)
Last post by: darkhorizon on 04-28-2014 10:17 AM
jknaack
Report this Post04-15-2014 10:47 PM Click Here to See the Profile for jknaackSend a Private Message to jknaackEdit/Delete MessageReply w/QuoteDirect Link to This Post
i have just recently purchased a 86 gt with a series 2 3800 swap.
car needs an alignment so i was wondering if there are certian specs thati need to give to the alignment shop so that everything rides the way it should.
any input or help from anyone would be greatly appricated. thanks
wftb
Report this Post04-15-2014 11:29 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
if you have stock suspension , your alignment shop can only align it to 86 gt specs .if they have a modern machine , they will have all the specs already .If they ask you for specs , take it some where else .the non stock engine does not dictate different alignment specs .
darkhorizon
Total ratings: 451
Report this Post04-16-2014 08:59 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Alignment is more related to what type of racing you will be doing. A street alignment will use street specifications
jknaack
Report this Post04-27-2014 10:26 PM Click Here to See the Profile for jknaackSend a Private Message to jknaackEdit/Delete MessageReply w/QuoteDirect Link to This Post
its mainly a street car ill probly takeit down the track a couple times just to see what it runs.
but as for alignment in the rear what should the camber an toe be set at to ensure it pull straight when i really get on it
darkhorizon
Total ratings: 451
Report this Post04-28-2014 10:17 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
if you want straight line specs, run a bit positive static camber in the rear. Toe should still be slightly neg, I run stock toe rear, and almost 0-0 front toe.
