  Headlight motors
Headlight motors by vizzionn
Started on: 04-15-2014 10:28 AM
Replies: 7 (261 views)
Last post by: vizzionn on 04-17-2014 03:57 PM
vizzionn
Report this Post04-15-2014 10:28 AM Click Here to See the Profile for vizzionnSend a Private Message to vizzionnEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok on my 88 fiero i have rebuilt the headlight motors they worked for like a week now they wont go up but they will go down any insight would be great and appreciated .
Report this Post04-15-2014 01:14 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The switch can get sloppy. Have you done any work on that?
vizzionn
Report this Post04-15-2014 02:41 PM Click Here to See the Profile for vizzionnSend a Private Message to vizzionnEdit/Delete MessageReply w/QuoteDirect Link to This Post
by switch what do you mean ? and no only thing i have touched is the motors
Report this Post04-15-2014 03:17 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The light switch on the Inst. panel...
vizzionn
Report this Post04-16-2014 07:53 AM Click Here to See the Profile for vizzionnSend a Private Message to vizzionnEdit/Delete MessageReply w/QuoteDirect Link to This Post
no i didnt touch that its been turning the headlights on and off its just the movement of the headlights i have a problem with they wont go up but they will go down
Report this Post04-16-2014 12:07 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Part of the switch does that also. There are metal tabs that bend and loose contact. Try pushing the button in various ways to make the lights move.
TbirdMarc
Report this Post04-17-2014 10:52 AM Click Here to See the Profile for TbirdMarcClick Here to visit TbirdMarc's HomePageSend a Private Message to TbirdMarcEdit/Delete MessageReply w/QuoteDirect Link to This Post
The headlight motors get the voltage for 'down' from the headlight switch. The voltage for 'up' is provided by seperate wires that go thru the fuse links under the front hood. It's unlikely that both would blow together but check for voltage right after the fuse links.
vizzionn
Report this Post04-17-2014 03:57 PM Click Here to See the Profile for vizzionnSend a Private Message to vizzionnEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks for the info ill have to check that out
