  84' SE: Wobbling timing mark
84' SE: Wobbling timing mark by mckaymotoworks
Started on: 04-13-2014 09:02 PM
Replies: 8 (170 views)
Last post by: mckaymotoworks on 04-13-2014 09:56 PM
mckaymotoworks
Report this Post04-13-2014 09:02 PM Click Here to See the Profile for mckaymotoworksClick Here to visit mckaymotoworks's HomePageSend a Private Message to mckaymotoworksEdit/Delete MessageReply w/QuoteDirect Link to This Post
We set timing last week to 8*, but noticed the mark was jumping around every couple of revolutions between 4-10* What would cause this most likely?
A search on the net points to the distributor on quite a few cars, though none specifically mention the Fiero. I have been told vacuum (all lines intact and clear), cam shaft gear (was told when it goes, it just goes) or distributor. I cleaned up all the grounds today.
What about the coil? I noticed the car sounds like it has a miss listening to the exhaust while I burped the cooling system.
Since the ECM controls the advance, is that a possibility? I get code "12" and it notices when sensors are disconnected, so it seems to function properly.
Would I be better off at this point buying a ALDL connector w/software so I can see what the car is doing while running?
Cygnus
Report this Post04-13-2014 09:16 PM Click Here to See the Profile for CygnusSend a Private Message to CygnusEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not sure if the ALDL will tell you why the timing is jumpy. Isn't the jumper you use to set timing supposed to eliminate influences from the ECM? However, getting an ALDL cable and software is a good thing to do. If you're into troubleshooting and fixing things yourself, it's a mighty handy tool.
mckaymotoworks
Report this Post04-13-2014 09:21 PM Click Here to See the Profile for mckaymotoworksClick Here to visit mckaymotoworks's HomePageSend a Private Message to mckaymotoworksEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes the jumper is supposed to eliminate that, and it was jumped with it in that mode as we set timing.
I really suspect the distributor as my symptoms align with the ones I've read, but like I said, other GM/Ford models.
Couldn't find anything here or online with a Fiero having this issue.
Report this Post04-13-2014 09:22 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
A well worn timing chain.
mckaymotoworks
Report this Post04-13-2014 09:25 PM Click Here to See the Profile for mckaymotoworksClick Here to visit mckaymotoworks's HomePageSend a Private Message to mckaymotoworksEdit/Delete MessageReply w/QuoteDirect Link to This Post
I thought that too, but discovered the 84' is a cam shaft gear on gear setup.
Thought maybe a missing tooth, but was told they just strip and go.
Report this Post04-13-2014 09:30 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
oops,,,, you have a Duke....sorry. How does the bottom of the distributor look?
mckaymotoworks
Report this Post04-13-2014 09:32 PM Click Here to See the Profile for mckaymotoworksClick Here to visit mckaymotoworks's HomePageSend a Private Message to mckaymotoworksEdit/Delete MessageReply w/QuoteDirect Link to This Post
Haven't pulled it yet. You mean the shaft area correct?
Report this Post04-13-2014 09:34 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
You can check for play in the rotor, and check for resistance in the shaft. Sometimes they dry out and get sticky...and the gears get sloppy on the bottom.
mckaymotoworks
Report this Post04-13-2014 09:56 PM Click Here to See the Profile for mckaymotoworksClick Here to visit mckaymotoworks's HomePageSend a Private Message to mckaymotoworksEdit/Delete MessageReply w/QuoteDirect Link to This Post
Forgot to mention I can feel it if I'm at a cruising speed, like between 40-50 MPH, I feel the car pulsing.
Though the tach nor Speedo show any movement in sync with the pulse. Like a slight stutter/jumping.
