  Fiero Tire load Index? (Page 2)
Fiero Tire load Index? by jscott1
Started on: 04-12-2014 09:28 PM
Replies: 49 (870 views)
Last post by: jscott1 on 04-23-2014 12:10 AM
dobey
Total ratings: 371
Report this Post04-22-2014 01:18 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by jscott1:
No the sidewall didn't rub, it's smooth as butter.
OK. In the other pic, the sidewall looked dirtier where the rim was bent, than around the rest of the tire, but maybe lighting. It's possible for the sidewall to rub a tiny bit, and still look new, aside from being a bit dirtier than the rest of the tire as well.
But yeah, if your tires were as low was 20psi on pressure, that's not good. Were they not visibly low with the car sitting on the ground, before you drove off?
jaskispyder
Total ratings: 205
Report this Post04-22-2014 01:21 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by dobey:
Low profile tires are going to have less flexible sidewalls anyway, simply because the sidewalls are shorter and there is much less potential for the wall to flex. That's why they are harder to mount than taller profile tires.
They still have give... let the air out of a tire and see what happens Run flats are stiff enough to keep the their shape if the tire loses air.
jscott1
Total ratings: 415
Report this Post04-22-2014 02:30 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
No my tires were not low, that tire was mounted less that 24 hours earlier. My point was that i don't think a properly inflated 40 series tire can flex thatTN much that its doubled over. The tire is still holding pressure at 30 psi.
David Hambleton
Report this Post04-22-2014 04:05 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have a look at this video by Michelin:
https://www.youtube.com/watch?v=Eg_t9qE4Jik
dobey
Total ratings: 371
Report this Post04-22-2014 04:40 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
It seems that that video is advertising tires from Michelin that flex more to theoretically distribute the energy through out the tire rubber, rather than having it transmitted through the suspension and steering, as would happen with stiffer tires, specifically for the purpose of absorbing shock from potholes. Watching the "slow motion" portions of that video, I'm really surprised the wheels weren't damaged in it. The wheels were very close to full contact with the steel bars they used for the curb and pothole.
David Hambleton
Report this Post04-22-2014 05:35 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by dobey:, I'm really surprised the wheels weren't damaged in it. The wheels were very close to full contact with the steel bars they used for the curb and pothole.
Precisely the point. A well designed video at a specific speed to show how the tire folds to absorbs the impact. A little bigger obstacle, a little more speed, an ordinary tire & you get a bent rim.
dobey
Total ratings: 371
Report this Post04-22-2014 06:36 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's showing how a *specific* tire that is a little underinflated, and is designed to fold in a certain way, is folding to absorb the impact.
Anyway, I'm not disagreeing with the possibility. Just that that video makes me want to avoid Michelin tires.
jscott1
Total ratings: 415
Report this Post04-22-2014 07:42 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah this is all fun arguing academics, but I still have two damaged wheels that I need to go out right now and replace.
And I don't believe any video that talks about Tyres and Kerbs. What the heck are those anyway.
David Hambleton
Report this Post04-22-2014 07:55 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you try a google search on wheel repair? It's surprising what can be fixed; yours don't look too bad compared to some...
jscott1
Total ratings: 415
Report this Post04-23-2014 12:10 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah I did a search and there are many places right here in Houston. I'm going to try, but first things first. I'm trying to get the car ready for a show this weekend, and I'm going to need ANOTHER set of tires. My spare wheels from the back yard have tires, but they are not in top condition.
