  Horn problem...
Horn problem... by fiero2kewl
Started on: 04-11-2014 07:01 PM
Replies: 6 (151 views)
Last post by: theogre on 04-13-2014 11:13 AM
fiero2kewl
Report this Post04-11-2014 07:01 PM Click Here to See the Profile for fiero2kewlSend a Private Message to fiero2kewlEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 88 coupe horn worked when I bought the car and one day poof no more. I hooked up the meter hit the button and got .34 volts.... I hear the relay clicking when you push the button... why isn't there 12volts at the horn?
trotterlg
Report this Post04-11-2014 07:27 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Because the fuse is blown?
[This message has been edited by trotterlg (edited 04-11-2014).]
fiero2kewl
Report this Post04-12-2014 02:18 PM Click Here to See the Profile for fiero2kewlSend a Private Message to fiero2kewlEdit/Delete MessageReply w/QuoteDirect Link to This Post
fuses are good.... the relay clicks under the dash so theres power its just not making it to the horn.... well .34 volts is.
Report this Post04-12-2014 02:34 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
I think the horn grounds through it's attachment screw.....so you may want to take if off the car and clean everything.
rennoc442
Report this Post04-13-2014 09:22 AM Click Here to See the Profile for rennoc442Send a Private Message to rennoc442Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey a fellow titusvillian! Where in tville are you?
seajai
Total ratings: 51
Report this Post04-13-2014 09:47 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is the wiring diagram for the horn circuit. For testing, buy yourself a good quality 12volt test light. If you can hear the relay click, the that portion of the circuit is good. The contacts in the horn relay could be bad. With the test light clipped to a good ground, disconnect both horns and probe the terminal with the test light while pressing the horn button. If the light does not illuminate, I would replace the horn relay.
Report this Post04-13-2014 11:13 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Relay click does not = good relay. Just means relay coil is ok.
take off relay cover to check contacts. Burn etc then get a new relay.
See my Cave, Horn
