  3800 SC compressor and R-12
3800 SC compressor and R-12 by TbirdMarc
Started on: 04-11-2014 12:56 PM
Replies: 2 (187 views)
Last post by: TbirdMarc on 04-11-2014 04:23 PM
TbirdMarc
Report this Post04-11-2014 12:56 PM Click Here to See the Profile for TbirdMarcClick Here to visit TbirdMarc's HomePageSend a Private Message to TbirdMarcEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will a 3800 compressor from a '96 work with R-12 or do I need to use R-134a? I have a bunch of R-12 refrigerant and service/recovery equipment for it and would prefer to use over the newer stuff. I do know I would have to have custom lines built to interface the compressor with the firewall lines.
daniel87fierogt
Total ratings: 52
Report this Post04-11-2014 01:28 PM Click Here to See the Profile for daniel87fierogtSend a Private Message to daniel87fierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am using my 3800 compressor with R12 in the system. The R12 actually has less head pressure so it works the compressor not as hard as when it had R134 in it. You have to make sure that you flush the compressor out really good to get out all the PAG oil that it has in it. I used AC flush and ran it through the compressor by hand about 3 times. I then put 2 oz of mineral oil into the compressor before i put the compressor back on the motor.
TbirdMarc
Report this Post04-11-2014 04:23 PM Click Here to See the Profile for TbirdMarcClick Here to visit TbirdMarc's HomePageSend a Private Message to TbirdMarcEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the reply. I will probably go this route. What did you use for the AC lines? Did you have custom made? I think the high pressure switch is already part of the compressor.
