  temperature gauge
temperature gauge by Firefighter
Started on: 04-09-2014 08:02 PM
Replies: 1 (130 views)
Last post by: Gall757 on 04-09-2014 09:02 PM
Firefighter
Report this Post04-09-2014 08:02 PM Click Here to See the Profile for FirefighterSend a Private Message to FirefighterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Regarding my '87 GT.
Just started up my '87 GT after the winter and my temperature gauge is vibrating very rapidly in all directions. It never shows the correct temperature even after just starting the engine.
Do I assume that the problem is the water temperature sensor in the engine block? If so, is it the sensor in the top right side of the block with one wire or the sensor in the right side of the block with the connector that has two wires? Both are a pain to get to in order to install a new part, so if you tell me the car is haunted that would be OK to:-)
Anyone ever have this same problem?
Thanks for the advice.
Report this Post04-09-2014 09:02 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The sensor for the gauge is on the driver side (near the ignition coil).. There are 2 leads, one is for the idiot light. Many fieros have been re-wired because it seems these things never worked right from the factory.
Learn about the re-wiring here:
http://www.fierosails.com/tempgage.html
[This message has been edited by Gall757 (edited 04-09-2014).]
