  Anyone used THESE ??
Anyone used THESE ?? by Lou6t4gto
Started on: 04-07-2014 07:20 PM
Replies: 14 (582 views)
Last post by: 1986Fiero on 04-12-2014 01:34 PM
Lou6t4gto
Report this Post04-07-2014 07:20 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.ebay.com/itm/MK1...00011%26prg%3D9311%2 6rk%3D1%26rkt%3D10%26sd%3D141173615873
EvilSqueezles
Report this Post04-07-2014 07:45 PM Click Here to See the Profile for EvilSqueezlesSend a Private Message to EvilSqueezlesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kinda funny. I asked that question 4-5 months ago and got a very basic opinion saying they are garbage. I dont know personally, didnt try them. I ended up finding some another member had built and switched out to put Konis in.
~James
Custom2M4
Total ratings: 114
Report this Post04-07-2014 08:06 PM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
It would be better in my opinion to Modify your existing struts and use coil over sleeves. They would then be adjustable and give you more wheel clearence. That way when you want to spend the money, you can just transfer over the coil overs to a good set of struts down the line.
Lou6t4gto
Report this Post04-07-2014 11:18 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok, guess I'll go with KYB. I THINK I should be able to get 235/60 x15s on there with the stock springs.
jimbolaya
Total ratings: 114
Report this Post04-08-2014 07:12 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post04-08-2014 07:53 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
My Formula had 235/60/15's on it from the PO. No clearance issues.
mitchjl22
Report this Post04-09-2014 12:37 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
Someone didn't like them...
Feedback
-Mitch
Diamond Dave
Report this Post04-10-2014 01:12 AM Click Here to See the Profile for Diamond DaveSend a Private Message to Diamond DaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unless you have proper offset you will run into problems. I have 235 60Rs in the back and they have rubbed the fenders and have worn holes in the wheel well liners.
BillS
Report this Post04-10-2014 11:16 AM Click Here to See the Profile for BillSSend a Private Message to BillSEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guess no one knows what brand those shocks really are - could be anything.
I fitted Konis all around on my car 20 years ago and they were a great investment.
Today, I'd look at BC Racing, which is what I use on my Solstice. $1K a set and well worth it, but you'd have to see if they can make them up for the Fieros. Adjustable abutments and rebound etc. The next step up from there is about 3X the price.
Lou6t4gto
Report this Post04-11-2014 01:39 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
well, I bought KYBs, they got here today, Now to find the TIME to install them ! Thanks for the oppinions
ConvictedRedneck
Report this Post04-12-2014 09:02 AM Click Here to See the Profile for ConvictedRedneckSend a Private Message to ConvictedRedneckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Make sure you do it the way described in the link that was posted and not the way those "coilovers" were made with the coils on the stock spring perch...not enough travel. I used A-1 Racing sleeves and adjusters and Black Magic Racing Springs. I forget what size exactly, that's just a generic link to them. They seemed to be the best bang for the buck from what I could find.
My turbo build
1986Fiero
Report this Post04-12-2014 01:16 PM Click Here to See the Profile for 1986FieroSend a Private Message to 1986FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have these on my car and they are perfectly fine. I bought them over two years ago and honestly they are great. 235/40/17.
Lou6t4gto
Report this Post04-12-2014 01:20 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
"I have these on my car and they are perfectly fine" - The ones I asked about ??
EvilSqueezles
Report this Post04-12-2014 01:25 PM Click Here to See the Profile for EvilSqueezlesSend a Private Message to EvilSqueezlesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Even if they work fine. With the little extra cost and effort of building your own, you'll gain much more adjustability and probably longevity. Not to mention you can just switch them over when its time to replace your struts.
~James
1986Fiero
Report this Post04-12-2014 01:34 PM Click Here to See the Profile for 1986FieroSend a Private Message to 1986FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. The mookeeh ones. I actually love them for the price.
