  Eliminating EGR on 98 3800 SC
Eliminating EGR on 98 3800 SC by Eglaore
Started on: 04-07-2014 05:09 PM
Replies: 4 (244 views)
Last post by: Eglaore on 04-09-2014 03:37 PM
Eglaore
Report this Post04-07-2014 05:09 PM Click Here to See the Profile for EglaoreSend a Private Message to EglaoreEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am getting ready to install a 3800 sc in my 85 fiero and I noticed the carbon build up in my Super charger and was thinking about removing the EGR. I was wondering what the pro's and Con's are to doing it and how you do it.
Thanks
sco77
Report this Post04-07-2014 06:57 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Pros? There really are none except the less carbon intake
Cons? MPG, emissions
How? block the passage on the LIM and exhaust manifold, have it tuned and deleted from computer.
86 Fiero GT 4spd - L67 swap: VS cam, GenV
98 GTP - Some mods
FieroJimmy
Report this Post04-08-2014 10:05 PM Click Here to See the Profile for FieroJimmySend a Private Message to FieroJimmyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just keep in mind you'll still get carbon from the pcv system, so it won't eliminate the carbon entirely. And properly tuning out the egr is more complex than just turning off the codes, fuel and timing will need adjusted to compensate for the increase in available oxygen while cruising. Egr on gas engines isn't used except for while cruising. (Diesels are a different story, egr is constantly in use, even during cold start idling to assist in warm up.)
BlackEmrald
Report this Post04-08-2014 11:33 PM Click Here to See the Profile for BlackEmraldSend a Private Message to BlackEmraldEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you sure that the carbon you are seeing isn't the teflon coating on the supercharger rotors?
Eglaore
Report this Post04-09-2014 03:37 PM Click Here to See the Profile for EglaoreSend a Private Message to EglaoreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its right after the throttle body so pretty sure.
