  swaping from a manual to an automatic non-computer controlled car
swaping from a manual to an automatic non-computer controlled car by fierocarb
Started on: 04-07-2014 08:24 AM
Replies: 2 (162 views)
Last post by: phonedawgz on 04-07-2014 05:45 PM
fierocarb
Report this Post04-07-2014 08:24 AM Click Here to See the Profile for fierocarbSend a Private Message to fierocarbEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 1988 with a carbed V6 and 5-speed manual set-up so there is no computer at all. Frankly I am now having problems with the clutch hydraulics and I am getting tired of shifting anyway. So as a crazy thought what about just swapping it out for a good automatic. So what I need is any insight anyone can provide about a non-computer controlled automatic transmission would be very helpful. For example:
1. Which transmission would work the best for my application
2. What would be all involved with switching to automatic, parts wise
Fadingaway
Report this Post04-07-2014 10:58 AM Click Here to See the Profile for FadingawaySend a Private Message to FadingawayEdit/Delete MessageReply w/QuoteDirect Link to This Post
I Suggest the 4t60 or 4t65hd trans they are strong reliable and have better gear ratios than the stock Fiero th125 and will work great with your application, I plan on running the 4t65hd after I carb my 2.5. Swap parts I know you will need are : Axles, auto shift cable, auto shifter assembly and other misc odds and ends. If you go with the 4t60/65 you need a shifter bracket adapter which you can make for purchase from ZZP
Total ratings: 291
Report this Post04-07-2014 05:45 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://myfiero.oceanmoon.co...sions/aod-conversion
http://myfiero.oceanmoon.co...iero-440-t44t604t60e
http://myfiero.oceanmoon.co...nsmission-conversion
You will have to figure out something for TCC lock up.
[This message has been edited by phonedawgz (edited 04-07-2014).]
