  code
code by krum
Started on: 04-05-2014 03:32 PM
Replies: 5 (129 views)
Last post by: 84fiero123 on 04-05-2014 08:40 PM
krum
Report this Post04-05-2014 03:32 PM Click Here to See the Profile for krumSend a Private Message to krumEdit/Delete MessageReply w/QuoteDirect Link to This Post
i dont understand this i hooked up a actron code scanner to my car the check engine light isnt on but i get a (code 12 No Distributor Reference Pulses) but the care idles and throttle responce is good what could be wrong with my distributor?
Report this Post04-05-2014 04:05 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
er......is this a Fiero engine? Code 12 is something else on OBD1.
krum
Report this Post04-05-2014 04:17 PM Click Here to See the Profile for krumSend a Private Message to krumEdit/Delete MessageReply w/QuoteDirect Link to This Post
yeah its a 84 se 2.5
http://www.actron.com/code_lookup.php
[This message has been edited by krum (edited 04-05-2014).]
krum
Report this Post04-05-2014 04:30 PM Click Here to See the Profile for krumSend a Private Message to krumEdit/Delete MessageReply w/QuoteDirect Link to This Post
krum
Member since Dec 2013
i just read up on this pos scanner it will give a code 12 even if there is nothing wrong
Report this Post04-05-2014 04:38 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
code 12 means everything is fine.....Actron's definitions are incomplete. Look below for if the engine is off or running....
https://www.fiero.nl/cgi-bin/main.cgi?ECMCodes
[This message has been edited by Gall757 (edited 04-05-2014).]
84fiero123
Total ratings: 325
Report this Post04-05-2014 08:40 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ayup, what he said, it should flash code 12 three times then any codes that a problems after that, then code 12 again to tell you that is all the bad codes
Steve
[This message has been edited by 84fiero123 (edited 04-05-2014).]
