  wheel spacers?
wheel spacers? by pgold
Started on: 04-01-2014 07:24 PM
Replies: 12 (1277 views)
Last post by: rogergarrison on 04-03-2014 12:15 PM
pgold
Report this Post04-01-2014 07:24 PM Click Here to See the Profile for pgoldSend a Private Message to pgoldEdit/Delete MessageReply w/QuoteDirect Link to This Post
A friend of mine is looking for some 2" wheel spacers. He currently has 4" wheel spacers and keeps breaking axles. Does anyone know where to get any wheel spacers?
I believe he has a 86 automatic with a 2.8.
84fiero123
Total ratings: 325
Report this Post04-01-2014 07:33 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
my first question is WHY?
Sorry got no answer but had to ask.
Steve
tebailey
Report this Post04-01-2014 07:40 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
pgold
Report this Post04-01-2014 07:43 PM Click Here to See the Profile for pgoldSend a Private Message to pgoldEdit/Delete MessageReply w/QuoteDirect Link to This Post
His car is a lamborghini roadster replica that someone else built. The guy that built the car didn't buy the right wheels with the right off set and he built it with 4" spacers on the wheels to make the wheels fit the body better. So after my friend has broken 3 axles he asked me to see if i could find him some 2" spacers to help take some stress off the axles. Just trying to help out a friend.
Neils88
Total ratings: 56
Report this Post04-01-2014 08:03 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Has he considered installing a widetrack suspension? Spacers throw off the geometry - anything more than an inch is not the best solution.
Bloozberry
Total ratings: 311
Report this Post04-01-2014 08:38 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
The axles are free floating so spacers don't place any stress on them. If they're breaking, it's due to some other reason.
Report this Post04-01-2014 08:54 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wouldn't 4" wheel spacers be a little tough on the wheel bearings?
Report this Post04-01-2014 10:36 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
axles or hubs?
usually axles won't break from just wheel loads. hubs will.
if axle(s) exactly what broke?
example, tearing CV can be
bad engine/trans mounts
poor location of trans
too short axles
johnguzman1212
Report this Post04-02-2014 01:55 AM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
i have a murcielago replica with 4 spacers on front I have no problem. in rear I have 2 inch spacers but I have real lambo wheels 13 wide in rear and 8,5 in front. im not breaking axles theres another problem. the spacers cant be the problem. I had 18 x 9 rockstars with 4 inch spacer in rear I had no problems with those. check something else maybe abusing car
johnguzman1212
Report this Post04-02-2014 01:57 AM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
johnguzman1212
Member since Feb 2014
obought all spacers from ebaY
rogergarrison
Total ratings: 551
Report this Post04-02-2014 10:15 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think your talking about ADAPTERS not spacers. 4" thick spacers would require at least 5" long studs I bought correct wheels for my Ferrari and Lambo kits with 4" added offset built in. Worked perfect and never had a bearing or axle failure in well over 100K.
I wont use adapters under any circumstances myself...ill pay for custom made rims.
johnguzman1212
Report this Post04-02-2014 11:03 PM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
that's a nice car! they make 2 inch spacers it goes from and to the same lug pattern they call them spacers / adapters . I used 2 inch spacer 5x100 to 5x100 and an adapter 5x100 to 5x120 to fit the lambo wheels. I didn't know you could have the offset made into the wheel . I couldn't with mine since there oem. both of the adapters / spacers have lugs and studs. I don't like this but I didn't have an option. the axle is being broken by something else
rogergarrison
Total ratings: 551
Report this Post04-03-2014 12:15 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe you have an adapter caused vibration that causing them to break. When you replace it, use a quality or OEM axle. Is the axle shaft itself breaking or the joint ? If you break them at the joint, you prob have cheap quality ones like Advance/Autozone. Mabe the bearings are bad and heating them up too.
