  282 whats each gear's mph?
282 whats each gear's mph? by LoW_KeY
Started on: 03-28-2014 11:45 AM
Replies: 5 (92 views)
Last post by: fieroguru on 03-28-2014 02:23 PM
LoW_KeY
Total ratings: 150
Report this Post03-28-2014 11:45 AM Click Here to See the Profile for LoW_KeYSend a Private Message to LoW_KeYEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok I have a rough idea, but wanted a more clear picture. I've used the search option but only come up with gearing which I already know. I just wanted to know becuase I planned on signing up for 1 mile run just want to make sure I'm not going to be limited here
riding on 17 inch tires
I want to say
1st - 30
2nd - 60
3rd - 90
4th - 120?
5th - ?
3800 SC/IC Formula whines more than your girl... 12.7@113 330 HP/430TQ
08 Cobalt SS TC - ZZP tuned, K&N SRI, 6k HID's 13.31@107
Total ratings: 255
Report this Post03-28-2014 11:54 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need to specify the outside diameter of your rear tires (or rear tire size) and the maximum RPM your engine can pull.
[This message has been edited by fieroguru (edited 03-28-2014).]
LoW_KeY
Total ratings: 150
Report this Post03-28-2014 12:02 PM Click Here to See the Profile for LoW_KeYSend a Private Message to LoW_KeYEdit/Delete MessageReply w/QuoteDirect Link to This Post
full tire size..? 205/45/17
(I know small) fixing that. 6k rpm. tried calculating it online calculator got 1st being 23 and 3rd 70...
dobey
Total ratings: 371
Report this Post03-28-2014 12:14 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just plug in the values on this page: http://www.car-videos.net/tools/speedrpm.asp
dobey
Total ratings: 371
Report this Post03-28-2014 12:18 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
dobey
Member since Sep 2001
it obviously depends on your RPM, but at 5500 (assuming your engine can handle that), you're looking at values very close to these:
30
52
77
113
147
[This message has been edited by dobey (edited 03-28-2014).]
Total ratings: 255
Report this Post03-28-2014 02:23 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
With your tires and 6000 RPM this would be the approximate maximum speeds
1st: 33.1
2nd: 56.5
3rd: 83.9
4th: 123.2
5th: 160.8
