  new radio/cd player
new radio/cd player by Csjag
Started on: 03-27-2014 03:28 PM
Replies: 3 (139 views)
Last post by: Csjag on 03-28-2014 05:25 AM
Csjag
Report this Post03-27-2014 03:28 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just installed the oem radio/cd player that I got from FieroTom today. It works great but I have a weird problem. When I turn on the cars parking lights the radio display goes out, the radio keeps playing. Any ideas on what this could be? Thanks
Report this Post03-27-2014 04:29 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's a grounding issue. If I was smarter I could tell you which ground, but maybe somebody else can. The stock radio uses 2 fuses.
http://home.comcast.net/~fierocave/sneakpath.htm
[This message has been edited by Gall757 (edited 03-27-2014).]
jscott1
Total ratings: 415
Report this Post03-27-2014 10:39 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Does it go completely off or just get dimmer? It's supposed to dim when you turn on your lights, but it sounds like it's dimming too much. Sounds to me like a defective radio. That dimming wire accepts 12V and is supposed to tell the radio it's time to dim. If there was a spurious ground you would probably pop a fuse, so it doesn't sounds like a ground issue to me.
[This message has been edited by jscott1 (edited 03-27-2014).]
Csjag
Report this Post03-28-2014 05:25 AM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
The display goes off completely but the radio keeps playing. I am going to check fuses today and also check and see if the parking lights and turn signals are working correctly.
