  shortening the throttle cable on my V8 powered 86GT
shortening the throttle cable on my V8 powered 86GT by hugh
Started on: 03-27-2014 09:47 AM
Replies: 1 (257 views)
Last post by: buildamonster on 03-27-2014 07:09 PM
hugh
Total ratings: 160
Report this Post03-27-2014 09:47 AM Click Here to See the Profile for hughSend a Private Message to hughEdit/Delete MessageReply w/QuoteDirect Link to This Post
As the title says I need to shorten the throttle cable on my 87GT ,If it were just shortening the internal cable,no problem,but I want to shorten the entire cable.Any help or advice will be appreciated,thanks!
#1112
Question my ability,question my intelligence,never question my integrity!
[This message has been edited by hugh (edited 03-27-2014).]
buildamonster
Report this Post03-27-2014 07:09 PM Click Here to See the Profile for buildamonsterSend a Private Message to buildamonsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did this to mine. It's not too hard to do. Go to the gas pedal and pull the cable out more than what you want to cut off. Do this so that you don't cut the internal cable. Then mark off how far you want to cut and get to work with a hack saw. You could use a very fine tooth blade in a jig saw or saw saw. Then push the inner cable out and use electrical tape around it at the point you want to cut and use the saw again. Use caution not to unwind the cable when cutting.
