  2000-2300 RPM Hesitation in 1985 2.8 V6 engine
2000-2300 RPM Hesitation in 1985 2.8 V6 engine by dreale
Started on: 03-26-2014 01:24 PM
Replies: 1 (246 views)
Last post by: Gall757 on 03-26-2014 02:49 PM
dreale
Report this Post03-26-2014 01:24 PM Click Here to See the Profile for drealeSend a Private Message to drealeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a problem that is getting worse - my 1985 V6 GT manual with 130,000 miles on it has a hesitation and stumbling in all gears around the 2000-2300 RPM range. Even in neutral, if I rev the engine to around 2000, it starts to stumble and hesitate. There is sometimes a loud buzzing noise from the engine in this RPM range, but it goes away when engine revs higher or lower. It is freaky in traffic because it feels like the clutch is slipping in and out even though it's not! The car lurches forward and back like it is not getting enough fuel, or timing is off. It starts fine, has great acceleration otherwise, and runs great except in that one RPM range. I just replaced the coil, rear spark plugs, and wires about a year ago, and the front spark plug wires, plugs, cap and rotor 3 days ago along with a new O2 sensor and EGR valve. Could it be the throttle position sensor? Coil? Or.....??? Thank you for any advice.
Report this Post03-26-2014 02:49 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Throttle Position Sensor may have a bad spot that would show up at the same RPM no matter what gear you are in. There is a test for it around here somewhere......
OK. this will help. http://www.gmtuners.com/tech/TPS_IAC.htm
[This message has been edited by Gall757 (edited 03-26-2014).]
