  Belts
Belts by 84 Fiero SE
Started on: 03-26-2014 11:56 AM
Replies: 2 (148 views)
Last post by: jaskispyder on 03-26-2014 12:23 PM
84 Fiero SE
Report this Post03-26-2014 11:56 AM Click Here to See the Profile for 84 Fiero SESend a Private Message to 84 Fiero SEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got a broken alternator belt on my 84 SE .... Is there an easy way to replace it, or should this be left to a Pro. ... Looks like it would have to be done from underneath ?
TONY_C
Report this Post03-26-2014 12:23 PM Click Here to See the Profile for TONY_CSend a Private Message to TONY_CEdit/Delete MessageReply w/QuoteDirect Link to This Post
You change it from the top. Loosen the two bolts on the alternator, slide the alternator towards the front of the car, put the new belt on the crank, water pump and alternator pulleys and use a long screwdriver or other suitable tool between the alternator and the bracket to move the alternator back enough to get the belt tight. Then tighten the two alternator bolts.
jaskispyder
Total ratings: 205
Report this Post03-26-2014 12:23 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need to be able to loosen the alternator (two bolts). Otherwise, yes, it can and usually is done from the top.
