Update System
  3800 n/a worth it?
3800 n/a worth it?
by rennoc442
Started on: 03-25-2014 02:26 PM
Replies: 17 (663 views)
Last post by: Ravant on 03-31-2014 09:27 PM
rennoc442
Report this Post Click Here to See the Profile for rennoc442Send a Private Message to rennoc442Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys, I need some help.
I found a 2002 3800 na rebuilt with 0 miles in a fiero. The thing is, I really want a sc engine and not a na. Would it be wise to go ahead and get this or just keep looking for a sc engine? Im sure there is head/piston changes between the 2, but figured I would reach out here.
Fierotregg
Report this Post Click Here to See the Profile for FierotreggClick Here to Email FierotreggSend a Private Message to FierotreggEdit/Delete MessageReply w/QuoteDirect Link to This Post
With 0 miles on it, get it, put SC top half on the NA long block and enjoy it.
darkhorizon
Total ratings: 449
Report this Post Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Turbo is even easier than supercharging!
weaselbeak
Total ratings: 76
Report this Post Click Here to See the Profile for weaselbeakClick Here to Email weaselbeakSend a Private Message to weaselbeakEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the n/a, and no need for the sc. It's plenty fast, just not stupid fast.
rennoc442
So other then the supercharger, what is different between the 2 engines? Heads, pistons?
Fierotregg
The bottom end is a little stronger in the SC motor.
aaronkoch
Report this Post Click Here to See the Profile for aaronkochClick Here to Email aaronkochSend a Private Message to aaronkochEdit/Delete MessageReply w/QuoteDirect Link to This Post
I purposely built a NA, used a 0 mile rebuilt motor (great deal, original owner's project fell through), and have ZERO regrets. Turbo is always a future option if you need more.
carbon
Total ratings: 130
Report this Post Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
No doubt! 205HP/230TQ in a Fiero is going to be a fun drive.
Lou and Blue
Report this Post Click Here to See the Profile for Lou and BlueClick Here to Email Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm looking for a 3800sc but I don't have a ton of money to spend. I'd rather have a supercharger than a turbo, don't like the turbo lag. But my stock 2.8 has a lot of pull so I guess I can wait till it's tired. Or if my supercharger itch gets so bad I have to scratch it.
Louis Duet
Baldwin, Long Island, NY
Where driving hard is SOP.
"Blue" <= '85 Fiero GT
Stock V6---Stock everything. Trying to keep it 'mostly' that way.
"Boo" <= '81 Delorean DMC-12
The "DuetLorean"
VIN #5835
Stock PRV engine
Robertson Equipped
Neiland/Delman Engineered
Carbed and loving it! (Peugot 604 manifold) ---"Sorry purists"
[This message has been edited by Lou and Blue (edited 03-28-2014).]
LoW_KeY
Total ratings: 150
Report this Post Click Here to See the Profile for LoW_KeYSend a Private Message to LoW_KeYEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used to be one of those turbo lag guys. I was use to turbos from the 80's cars. Now days its very very minimal! from what I experienced with my cobalt.
going na doesnt limit you with 0 miles why not?
3800 SC/IC Formula whines more than your girl... 12.7@113 330 HP/430TQ
08 Cobalt SS TC - ZZP tuned, K&N SRI, 6k HID's 13.31@107
rennoc442
Well since it seems like the engine is not as stout as an sc engine I'm going to keep looking. Plus the rebuild was with all stock parts, which I would have to change out.
MulletproofMonk
Total ratings: 78
Report this Post Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you are planning on swapping in a 3800sc series 2 later, do that zero mile 3800n/a series 2 now...
1. Wiring harness will be identical except for the plug on the MAP sensor and the SC uses a boost bypass solenoid (that most people don't wire)...
2. Mounts are the same...
3. Coolant routing is the same...
4. Fuel routing should be close to the same... Make sure to put in a fuel pump that will accommodate the SC motor later so you don't have to drop the tank again...
5. Exhaust dumps in the same place...
6. You will need a new PCM programmed for the 3800sc motor
Basically you would drop out the N/A and throw in the SC when you find one... but enjoy the benefit of:
1. 58% HP gain
2. Still run 87 octane
3. Better fuel economy
4. ODBii (I run TORQUE on my phone)
I am working on a 3800sc for my other car, but use my 3800n/a as a daily driver...
EDIT: I guess that it all depends on the cost of the 3800n/a motor. You could always turbo it like everyone says...
-Brian
Removing the roof panel
My HUD install thread
Modified stock air canister and base to 3.5 inch for 3800na
[This message has been edited by MulletproofMonk (edited 03-30-2014).]
rennoc442
Speaking of that torque app, which adapter do you use?
sco77
Report this Post Click Here to See the Profile for sco77Click Here to Email sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've tried a bunch of adapters and will no longer buy any other bluetooth adapter other than BAFX ELM327 with the blue label. Search amazon it's like $25 or something shipped.
86 Fiero GT 4spd - L67 swap: VS cam, GenV
98 GTP - Some mods
rennoc442
sco77
Originally posted by rennoc442:
Like this one?
http://www.amazon.com/gp/aw...sr=8-2&pi=SX200_QL40
That's it.. but your link takes me to like a text only version of amazon.
rennoc442
It was sent using my phone, at least its the right one!
Ravant
Report this Post Click Here to See the Profile for RavantSend a Private Message to RavantEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you use the right turbo, you can have full spool just off idle and maintain a torque plateau to redline. It's a matter of matching the size of the turbo to the size of the engine. A big turbo with a high, dyno-queen horsepower number won't spool 'til near redline. But a tiny turbo too small for the application will hit full spool at idle and will putter out halfway to redline. If you do it right, you could have an engine with the output similar to the 2.0T in the Sonata/Genesis 2.0 (second version) that did 274 horse at 6000 RPM and 269 ft-lbs of torque from 1800 to 4500 RPM. (Yes, a 2700 RPM torque band and a 4200 RPM powerband.) My 2011 Sonata SE Turbo was a crap car when it came to electrical reliability, but that little 2-liter really did put out that much power. The L36 can do that and much more with the right turbo.
There's a reason that some of the fastest L67's and LSJ's on the road simply gutted the superchargers and replaced them with turbos. Just sayin'.
