  hunting idle...
hunting idle... by AL87
Started on: 03-23-2014 11:03 PM
Replies: 10 (836 views)
Last post by: Lou and Blue on 03-29-2014 09:19 PM
AL87
Report this Post03-23-2014 11:03 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
2.8 hunts up and down on idle from 900-1300 code 22
car is 86 4spd gt. acceleration is fine. slight hesitation on throttle input.
Report this Post03-24-2014 07:45 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
fiero5150
Report this Post03-24-2014 10:26 AM Click Here to See the Profile for fiero5150Send a Private Message to fiero5150Edit/Delete MessageReply w/QuoteDirect Link to This Post
I changed the IAC on my 2.8 and that fixed the problem. No more idle hunting. Ordered A/C Delco part from Rock Auto.
AL87
Report this Post03-24-2014 11:34 AM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
Its time to diagnose the problem. I'll definitely test the IAC and TPS. also from another recent problem I've encountered the coolant temp sensor may be out of adjustment leading to the hunting idle. but im pretty sure the code 22 (low tps signal) is just the tps, its the only code, and its on consistently.
AL87
Report this Post03-25-2014 11:45 AM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
as predicted, the iac was adjusting constantly creating the hunting described.
that is most likely the combination of, or either of the two sensors. (IAC, and CTS)
the code 22 being the most anoying here because it just "switched" off like theres nothing coming from the tps anymore.
even when I pull the connector going to it, and play with the throttle, it still hesitates.
AL87
Report this Post03-25-2014 04:12 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
AL87
Member since Mar 2010
I diagnosed the tps, its getting voltage. black to black for ground and red to blue for voltage. getting from .2-6.5V low-high with an analog tester.
is there any way to test somewhere for the signal to the ecm?
the motor is acting like there isnt a tps connected. so somewhere there is a break to the ecm.
that would be the grey, right?
[This message has been edited by AL87 (edited 03-25-2014).]
AL87
Report this Post03-25-2014 06:27 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
AL87
update, i took the center console out to get to the ecm, and I found the blue wire to the tps, it looks like it had been tampered with at one point before me.
the wire was broken and the clip wasnt in good condition when I pulled it out. the retainer was gone. will attempt to correct and update later.
AL87
Report this Post03-28-2014 12:53 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good as new.
Lou and Blue
Report this Post03-28-2014 07:20 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the same idle hunting in my 85 GT. I got an IAC from ebay for $10.61 shipped. I haven't installed it yet though. I hope that's the issue.
Louis Duet
Baldwin, Long Island, NY
Where driving hard is SOP.
"Blue" <= '85 Fiero GT
Stock V6---Stock everything. Trying to keep it 'mostly' that way.
"Boo" <= '81 Delorean DMC-12
The "DuetLorean"
VIN #5835
Stock PRV engine
Robertson Equipped
Neiland/Delman Engineered
Carbed and loving it! (Peugot 604 manifold) ---"Sorry purists"
AL87
Report this Post03-29-2014 02:53 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
cross your fingers*
I diagnosed the vac lines, tps at its connector, IAC, CTS before I went to the ecm connectors.
Lou and Blue
Report this Post03-29-2014 09:19 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will install my new IAC and inspect the ECM wires as well. Thank you for the tip.
Louis Duet
The "DuetLorean"
VIN #5835
Stock PRV engine
Robertson Equipped
