  failed emissions on hydrocarbons
failed emissions on hydrocarbons by wolf63
Started on: 03-23-2014 10:19 PM
Replies: 9 (245 views)
Last post by: wolf63 on 03-28-2014 09:43 PM
wolf63
Report this Post03-23-2014 10:19 PM Click Here to See the Profile for wolf63Send a Private Message to wolf63Edit/Delete MessageReply w/QuoteDirect Link to This Post
so my 84 4cyl manual failed the Colorado emissions test. hydrocarbons at 4.55 with a 3.00 limit. it has a relatively minor miss at idle. the graph they gave me shows it spiking all over the place until it hits 50MPH then all the levels drop way down. i reset the timing and it seems a little better but it still has an occasional miss and i notice the timing mark moves around between 8 and 6, is that normal?. i switched the MAF? (the one on the side of the air cleaner) no effect. however, i did note that when i disconnected the EGR vac line nothing happens. finger on the port feels no vac at all. higher revs get a small vac but still not much. is that normal? appreciate any help.
Report this Post03-24-2014 07:56 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think it is normal. Is your idle speed around 900 rpm? If you pull a vacuum line does the idle go up? Is there oil in the air filter tray? There could be some carbon build up somewhere that is reducing the manifold vacuum, perhaps at the EGR valve.
wolf63
Report this Post03-24-2014 10:24 PM Click Here to See the Profile for wolf63Send a Private Message to wolf63Edit/Delete MessageReply w/QuoteDirect Link to This Post
idle is normal around 900ish, yes pulling a vacuum line raises the RPMs, yes it has oil in the air cleaner (some blow by but no smoke). however, pulling the vac line going to the EGR does not cause the rpms to change and a finger over the port on the throttle body does not register any vac at idle and raising the rpms only generates a very weak vacuum.
pull the throttle body and check for clogged port? net search indicates non functional EGR causes high NOx reading (and it isnt good but passes with 3.42 out of 4.5 allowed)
Rodrv6
Total ratings: 76
Report this Post03-25-2014 09:21 AM Click Here to See the Profile for Rodrv6Send a Private Message to Rodrv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had the same issue in the past when I had my 84. High HC with everything else within limits. It ended up being a bad catalytic convertor. A new one dropped the HC's way down and it passed easily..........
Rod Schneider, Ball Ground, Ga.
"You can't have too many toys!"
1988 Fiero GT
1987 Porsche 944S
1987 Corvette
1966 Porsche 911
2001 Chrysler 300M
Van's RV-6 airplane
wolf63
Report this Post03-25-2014 09:03 PM Click Here to See the Profile for wolf63Send a Private Message to wolf63Edit/Delete MessageReply w/QuoteDirect Link to This Post
thats the plan for tomorrow morning :-) getting the cat replaced and installing a new O2. we'll see how that goes.
Marvin McInnis
Total ratings: 227
Report this Post03-26-2014 07:11 PM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by wolf63:
... when i disconnected the EGR vac line nothing happens. finger on the port feels no vac at all. higher revs get a small vac but still not much. is that normal?
That is normal. EGR is active only during mid-throttle cruising, and it is disabled both at idle and near full throttle.
wolf63
Report this Post03-26-2014 08:18 PM Click Here to See the Profile for wolf63Send a Private Message to wolf63Edit/Delete MessageReply w/QuoteDirect Link to This Post
i found the EGR vacuum (or lack thereof) link using the pennock's search, so no worries there (thanks though)
so it now has a new CAT and O2 sensor. doesnt run any different although the sound is lower (kind of Evenrude-ish) :-)
i still have a random miss at idle thats driving me nuts, and worries me regarding the pending emissions re-check. ive checked for vac leaks (none). replaced plugs, wires, coil, swapped dist from my spare motor still have the same random miss.
next, lets talk timing. i set it as best i can to 8ish and that bothers me cuz it really is 8ish according to the timing light #1 is firing between 12 and 4 with it constantly moving. does that give anyone any ideas? i'm fresh out :-(
armos
Report this Post03-27-2014 08:38 AM Click Here to See the Profile for armosSend a Private Message to armosEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have the A-B pins on the ALDL connector jumpered when you check the timing?
Marvin McInnis
Total ratings: 227
Report this Post03-27-2014 12:52 PM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Assuming you have the two pins on the ALDL connector properly jumpered ... A couple of degrees of timing jitter, especially at idle, isn't unusual for a worn engine. Jitter can be introduced by a worn timing chain and/or gears, by a worn distributor drive gear, and by wear in the distributor itself.
wolf63
Report this Post03-28-2014 09:43 PM Click Here to See the Profile for wolf63Send a Private Message to wolf63Edit/Delete MessageReply w/QuoteDirect Link to This Post
woo hoo! dont know if it was the new CAT or the O2 sensor or both but it passed by a mile! HC dropped from 3.5something to .3something :-) thanks everyone for your help. Pennocks is a godsend :-)
