  Anyone considered these
Anyone considered these by cmechmann
Started on: 03-20-2014 12:21 AM
Replies: 3 (269 views)
Last post by: dobey on 03-20-2014 09:55 AM
cmechmann
Report this Post03-20-2014 12:21 AM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
steve308
Total ratings: 58
Report this Post03-20-2014 04:30 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
For what use?
cmechmann
Report this Post03-20-2014 08:13 AM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
These and other brands have been getting smaller and the amp loads are almost small enough to make these type compressors a viable replacement for belt driven compressors.
This is just an example of the many 12v DC compressors out there. I have been looking at these for several years. The sizes and pricing have been getting better all the time.
There are some with a 30-40 amp load capable of the 2500-3500 BTU range. Some of the horizontal type are just a little longer than a quart oil can. About the size of a "Big Gulp" cup.
Many that are doing engine swaps are finding restraints with room in the engine compartment. With that many have already increased their alternator capacity.
These could be mounted in the front compartment without hoses and shaft seals to leak. Could work with the stock condensor and evaporator.
I'm asking if anyone else has been looking in to this with more detail.
dobey
Total ratings: 371
Report this Post03-20-2014 09:55 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've seen them used in EV conversions before.
Personally, I'd prefer a solid state solution, but getting it cold enough can be difficult. Great thing about a good solid state solution though, is it could double as the heater and a/c, which means a lot less fluid line routing, and a lot more surface area for the air to contact.
