  new engine?
new engine? by johnguzman1212
Started on: 03-18-2014 05:04 PM
Replies: 12 (400 views)
Last post by: johnguzman1212 on 03-27-2014 02:47 AM
johnguzman1212
Report this Post03-18-2014 05:04 PM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
since everyone here has more experience give me advice please. I have a lambo replica based on a 87 2.5 iron duke I got 2000 bucks or more . the engine overheated went to 293 F now speed max is 65 but slow to get there. I am burning oil cause white smoke is coming out now and lifters tapping a little now more than before. I don't mind having a 2.5 again it has great fuel economy and ok power im not a speed freak. I built the whole car myself. buy a rebuilt engine? upgrade to 2.8? its automatic bty. get the engine rebuilt by mechanic? how easy is it to rebuild myself where is the thread for this? how easy is the conversion to 2.8? where is that thread? i don't trust the mecanics here they are idiots
tebailey
Report this Post03-18-2014 05:15 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check the eco-tech swap, might be within your price range without giving up the economy of the 4cyl.
Old Lar
Total ratings: 214
Report this Post03-18-2014 06:19 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any engine swap has issues with wiring and computers. Unless you have time and some expertise you could rebuild the engine, if it hasn't been wrecked. Me, I had a new crate engine installed by a qualified mechanic, but you would need to find a qualified, reliable in the area.
dobey
Total ratings: 371
Report this Post03-18-2014 06:47 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
White smoke isn't oil, it's coolant. If you overheated that much, you almost certainly blew the gasket, and may have cracked the head. That's why it is running so poorly.
It's not terribly hard to rebuild the engine. If you've cracked the head or block though, you're probably going to have to find another to replace it with. It shouldn't be too hard to find a 2.5L engine in the yard though, as it was used in many GM vehicles of the era.
84fiero123
Total ratings: 325
Report this Post03-19-2014 09:14 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Steve
Total ratings: 291
Report this Post03-19-2014 09:28 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Find a 2.8 Fiero that runs great and swap all the 2.8 components into your car. No need to wire anything special yourself. You will have been able to drive the engine/transmission so you will know what you are getting.
Lou6t4gto
Report this Post03-19-2014 09:59 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://www.fiero.nl/forum/Forum4/HTML/068578.html
Doesn't get any Easier than this, a "Direct, Complete, Swap". 4 bolts and 3 plugs ! Hope that helps. I agree, you probably have (at least) a blown head gasket.
tebailey
Report this Post03-19-2014 11:20 AM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you want easy just get another Duke.
KurtAKX
Total ratings: 128
Report this Post03-19-2014 11:40 AM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
There's a lot more to it than that.
Fuel lines are routed different, throttle cable, tachometer, fuel pump/sender, etc.
I know you're after a quick sale of your hardware, but you'll have to include the above mentioned parts (and more) for it to be as simple as you claim.
Lou6t4gto
Report this Post03-19-2014 11:55 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry, forgot about the fuel Lines and pump being different. Not looking for a "quick sale", really don't care if it sells or not. just trying to help.
Custom2M4
Total ratings: 114
Report this Post03-19-2014 05:01 PM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would upgrade, and probably skip the 2.8 and go to a More powerful option. It is a replica after all.
[This message has been edited by Custom2M4 (edited 03-19-2014).]
johnguzman1212
Report this Post03-27-2014 02:42 AM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
decesions man I hate these they all sound good might just buy another fiero with same engine do it myself and have an exrtra cradle for a new bigger engine.
johnguzman1212
Report this Post03-27-2014 02:47 AM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
johnguzman1212
Member since Feb 2014
[img]https://www.facebook.com/photo.php?fbid=689387037766067&set=pb.100000843304904.-2207520000.1395906396.&type=3&theater[/img]
