  F23 Spacer?
F23 Spacer? by 1986Fiero
Started on: 03-16-2014 02:05 PM
Replies: 23 (929 views)
Last post by: mcguiver3 on 05-14-2014 09:10 PM
1986Fiero
Report this Post03-16-2014 02:05 PM Click Here to See the Profile for 1986FieroSend a Private Message to 1986FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just finished my f23 swap on my 86 2.8l fiero and while bleeding the clutch im getting fluid leaking out of the bellhousing. I thought that when I used the stock clutch and flywheel I dont need a spacer for the HTOB? Obviously I either overextended the HTOB or I have a defective one. Do I need a spacer for the HTOB and what size does it need to be? Thanks.
mcguiver3
Report this Post03-16-2014 02:52 PM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thinking about doing this swap too.
Be interested in the definitive answer.
86fiero, where are you in CT?
I'm in Beacon Falls
PM me
Bob
FIEROFLYER
Total ratings: 180
Report this Post03-16-2014 03:05 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Reason for the spacer is the depth of the F23 bell housing so the spacer on the HTOB is still needed when mated up to the Fiero stock engines. Dan
1986Fiero
Report this Post03-16-2014 03:12 PM Click Here to See the Profile for 1986FieroSend a Private Message to 1986FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I figured I needed one after this happened. I have the stock 4 speed clutch in it. Does anyone know the size of the spacer im going to need?
fieroaddicted
Report this Post03-16-2014 03:51 PM Click Here to See the Profile for fieroaddictedSend a Private Message to fieroaddictedEdit/Delete MessageReply w/QuoteDirect Link to This Post
crappy deal man, probably in for a new clutch now...good luck
1986Fiero
Report this Post03-16-2014 04:06 PM Click Here to See the Profile for 1986FieroSend a Private Message to 1986FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
This was suppose to be the first test drive but since I have to add a spacer and take the tranny out I might as well put a new clutch in it. What clutch did everybody have good luck with for a 2.8?
wftb
Report this Post03-16-2014 04:37 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
there are quite a few f23 swap threads that have info .I think L67 ? had a good one , try the search .look at Trintens v8-f23 thread in the construction zone too
1986Fiero
Report this Post03-16-2014 04:45 PM Click Here to See the Profile for 1986FieroSend a Private Message to 1986FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I already looked through a couple hours of posts and i couldnt find what i needed. The spacer size is most likely different for a v-8 and a 3800. I have the 2.8 that came with the car but its a 3.1 stroker which doesnt matter with the spacer sizing.
wftb
Report this Post03-16-2014 06:31 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
try and PM Justinbart or Dark Horizon . I would think the spacer for a 3800 would at least be a good starting point and I think I remember that Spec makes one so get that part # .I think fieroflyer has that info too . I am not that knowledgeable on the subject , just going by memory here .good luck .
FIEROFLYER
Total ratings: 180
Report this Post03-16-2014 06:34 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
.250 or 1/4 inch as some call it is what pretty much all of the ones I have done needed
1986Fiero
Report this Post03-16-2014 08:44 PM Click Here to See the Profile for 1986FieroSend a Private Message to 1986FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the information. Ill double check the spacer length i need and make one to size. Thanks for the info everybody.
carbon
Total ratings: 130
Report this Post03-17-2014 08:43 AM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Was this an issue with the a Getrag clutches? I do know that the Muncie clutch and Getrag clutch use different throw out bearings and none of the early F23 threads even mention it being needed, but almost all were aftermarket Getrag clutches against 3800s...
I believe the real issue is that the Fiero master cylinder has a larger capacity than the J-body's... you can probably achieve the same results by spacing the master off the firewall or limiting pedal travel with a block...
F23 Clutch and Htob spacer question (measuring)
[This message has been edited by carbon (edited 03-17-2014).]
FIEROFLYER
Total ratings: 180
Report this Post03-17-2014 09:09 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
If you take the time to do some measurements of both trannies and how much space and movement there is off the throw out bearing on the Fiero and the HTOB on the F23 you will find you come up with a difference of approximately 1/4 of an inch more which causes the HTOB to ever extend and fluid leaks past its seals. Placing a block under the clutch pedal or moving the slave might work but the proper way is to use an HTOB spacer and be done with it. Dan
DARN Cars now open with
1986Fiero
Report this Post03-17-2014 12:17 PM Click Here to See the Profile for 1986FieroSend a Private Message to 1986FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had the muncie 4 speed in it before and im using the clutch from that because its almost new from when i did the clutch in it before. Ill have to rip it out and do some measuring. Thanks alot everybody!
mcguiver3
Report this Post03-17-2014 02:58 PM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
Along this same discussion...............
Is there a possibility that the F23 has a LSD option?
If so how would it be designated on the case? vin? anywhere?
Is there a particular vehicle that it would have been in?
1986Fiero
Report this Post03-17-2014 03:27 PM Click Here to See the Profile for 1986FieroSend a Private Message to 1986FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Im not 100% sure if you can get one already with an LSD but I know you can make it an LSD. OBX and Quaife offer what you need to do that. Would that be something that I should do when I take it out again?
mcguiver3
Report this Post03-17-2014 06:08 PM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
The aftermarket units are about a grand to buy.
I have the Engineered Performance unit in my current 282 and it's not that great.
I do know the Quafe unit is available but was told some time back that a few cars were built with it.
Just trying to find out if the info was correct and if so where to look
FIEROFLYER
Total ratings: 180
Report this Post03-17-2014 08:27 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe some of them were made with it but they are newer around 2010 or so which would require swapping the bell housing with an older one to make it bolt up to the Fiero engines.
Report this Post03-17-2014 09:01 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The OBX one is about $400 shipped.
http://www.ebay.com/itm/OBX...em258b0dfa2f&vxp=mtr
The SBC/F23 I am working on has a LSD, but it is a quaife and was added.
[This message has been edited by fieroguru (edited 03-17-2014).]
mcguiver3
Report this Post03-18-2014 06:43 AM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
That I did not know, and am pleasantly surprised.
Makes doing this a bit more palatable.
Better start saving my pennies
carbon
Total ratings: 130
Report this Post03-18-2014 08:40 AM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
To insure you have the best experience possible with an OBX Limited Slip Differential for the F23...
OBX LSD How To
Edit: The link is from 2011, whether the issues have been corrected in the current product, I cannot say.
[This message has been edited by carbon (edited 03-18-2014).]
Purple86GT
Total ratings: 62
Report this Post05-14-2014 09:44 AM Click Here to See the Profile for Purple86GTSend a Private Message to Purple86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Called SPEC and spoke to Jerrimy. The spacer needed is the .250" and the part number is N1774-.250 Bearing Cap. They told me it is $49 plus shipping. Hope this info helps others as it was hard gor me to find.
1986Fiero
Report this Post05-14-2014 04:28 PM Click Here to See the Profile for 1986FieroSend a Private Message to 1986FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had an extra htob and cut the hardened part off that touches the clutch fingers and made a 1/4" spacer out of it and welded it to the new htob. Now it works perfect.
mcguiver3
Report this Post05-14-2014 09:10 PM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
Scott,
does that mean you will be driving it down to Thompson Sunday to The CART event?
Bob
