  Cigarette Lighter - Bulb?
Cigarette Lighter - Bulb? by Ravant
Started on: 03-14-2014 01:10 PM
Replies: 5 (383 views)
Last post by: theogre on 03-16-2014 08:15 PM
Ravant
Report this Post03-14-2014 01:10 PM Click Here to See the Profile for RavantSend a Private Message to RavantEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ground outside, hot center, but what goes in the torpedo-looking attachment? I've got a third, empty wire that plugs into it, needs a bulb. What bulb plugs into it so I can get that and a new lighter?
[This message has been edited by Ravant (edited 03-14-2014).]
Report this Post03-14-2014 03:05 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
OE Bulb is 194.
See my Cave, Lighter
Ravant
Report this Post03-15-2014 09:27 AM Click Here to See the Profile for RavantSend a Private Message to RavantEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got it, thanks.
Total ratings: 154
Report this Post03-16-2014 10:59 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would recommend leaving the bulb out. If you're driving, you can feel for the location. If you're not driving, you can look down to find it. It does little to aid in seeing the lighter socket and it generates enough heat that it causes the soft vinyl above the lighter trim plate to turn loose and buckle. Same goes for the little ash tray bulbs.
sco77
Report this Post03-16-2014 04:10 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
You can get around this by replacing it with an LED, no heat.
86 Fiero GT 4spd - L67 swap: VS cam, GenV
98 GTP - Some mods
Report this Post03-16-2014 08:15 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
The way this socket is made and location are headaches.
1. Light house is a very small hole and light output is blocked on most socket.
2. When does work, can make glare problem reflect on windshield. Many find this bulb is annoying at best.
