  GT tail light metal bracket
GT tail light metal bracket by TheDave
Started on: 03-13-2014 09:22 AM
Replies: 4 (185 views)
Last post by: seajai on 03-13-2014 07:37 PM
TheDave
Report this Post03-13-2014 09:22 AM Click Here to See the Profile for TheDaveSend a Private Message to TheDaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure of the official term for this part but as you can see in the picture below there was some sort of finish on these and I do not think it was just paint. These are the 3 clips that hold the GT tail light on with the long 7 inch screws. I was thinking of dipping these in Plasti Dip. What are you thoughts.
Regards,
David
86 Vintage Fiero
Report this Post03-13-2014 10:25 AM Click Here to See the Profile for 86 Vintage FieroSend a Private Message to 86 Vintage FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you planning on driving during winter months? If so, then any protection is good. I have used the dip on tools but I have always wondered what would happen on car parts! The only down side would be if the protective coating got torn, which would allow water and salt (if driven in the winter months) to corrode the metal. Something on the metal has to help. Hope it works out.
Report this Post03-13-2014 11:53 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Likely won't help. Screw will "saw thru" the dip. Then dip can help water to rust more, likely faster.
Use whatever to convert rust to anti-rust coating. Clean off big flakes only, not all of it.
Vanet
Report this Post03-13-2014 05:35 PM Click Here to See the Profile for VanetSend a Private Message to VanetEdit/Delete MessageReply w/QuoteDirect Link to This Post
They have paints that kill rust and stop it from coming back. That would probably be better than plasti-dip. The one that comes to mind is POR-15, but it is expensive and some of the ones you buy at the hardware store work just as well for a lot less.
seajai
Total ratings: 51
Report this Post03-13-2014 07:37 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.por15.com/
Used this on my cradle and other parts, works great.
Starter kit is only $22 bucks
http://www.por15.com/SUPER-...KIT--Black_p_11.html
[This message has been edited by seajai (edited 03-13-2014).]
